I'm working on the ESR measurement (m-firmware) at the moment and like to ask you for some beta testing. For testing you would have to replace the function MeasureESR() in cap.c with following:
* measure ESR
* requires:
* - pointer to cap data structure
* returns:
* - ESR in 0.01 Ohm
* - UINT16_MAX on any problem
uint16_t MeasureESR(Capacitor_Type *Cap)
uint16_t ESR = UINT16_MAX; /* return value */
uint16_t U_1; /* voltage at probe 1 with pos. pulse unloaded */
uint16_t U_2; /* voltage at probe 2 with pos. pulse loaded */
uint16_t U_3; /* voltage at probe 2 with neg. pulse unloaded */
uint16_t U_4; /* voltage at probe 1 with neg. pulse loaded */
uint8_t Probe1; /* probe #1 */
uint8_t Probe2; /* probe #2 */
uint8_t ADC_Mask; /* bit mask for ADC */
uint8_t n; /* counter */
uint32_t Sum_1; /* sum #1 */
uint32_t Sum_2; /* sum #2 */
uint32_t Value;
/* check for a capacitor >= 10nF */
if ((Cap == NULL) ||
(CmpValue(Cap->Value, Cap->Scale, 10, -9) < 0)) return ESR;
* init stuff
DischargeProbes(); /* try to discharge probes */
if (Check.Found == COMP_ERROR) return ESR; /* skip on error */
UpdateProbes(Cap->A, Cap->B, 0); /* update probes */
Probe1 = Probes.ADC_1; /* ADC MUX for probe-1 */
Probe2 = Probes.ADC_2; /* ADC MUX for probe-2 */
Probe1 |= ADC_REF_BANDGAP; /* select bandgap reference */
Probe2 |= ADC_REF_BANDGAP; /* select bandgap reference */
/* bitmask to enable and start ADC */
ADC_Mask = (1 << ADSC) | (1 << ADEN) | (1 << ADIF) | ADC_CLOCK_DIV;
/* init variables */
Sum_1 = 1; /* 1 to prevent division by zero */
Sum_2 = 1; /* 1 to prevent division by zero */
* We have to create a delay to shift the middle of the current pulse to
* the ADC's S&H. S&H happens at 1.5 ADC clock cycles after starting the
* conversion. We synchronize to a dummy conversion done directly before,
* so we have 2.5 ADC clock cycles to S&H. The required delay between the
* dummy conversion and S&H of the next conversion is:
* MCU cycles for 2.5 ADC clock cycles
* - MCU cycles for waiting loop for completion of dummy conversion (4)
* - MCU cycles for starting next conversion (2)
* - MCU cycles for fixed pre-delay of 10µs
* - MCU cycles for enabling pulse (4)
* - MCU cycles for half-pulse (2µs)
* MCU ADC MCU cycles for
* clock clock 2.5 ADC cycles pre-delay half-pulse delay
* 8 MHz 125 kHz 160 (20µs) 80 (10µs) 16 (2µs) 54
* 32 (4µs) 38
* 16 MHz 125 kHz 320 (20µs) 160 (10µs) 32 (2µs) 118
* 64 (4µs) 86
* 20 MHz 156.25 320 (16µs) 200 (10µs) 40 (2µs) 70
* 80 (4µs) 30
* Skipping the second half-pulse allows us to measure low value caps too.
/* delay for pulse */
/* MCU cycles for one ADC cycle * 2.5 - MCU cycles for 10µs
- MCU cycles for half-pulse - 10 */
U_1 = ((MCU_CYCLES_PER_ADC * 25) / 10) - (MCU_CYCLES_PER_US * 10)
- (MCU_CYCLES_PER_US * 2) - 10;
#if CPU_FREQ == 8000000
/* magic time shift to compensate missing second half-pulse */
U_1 -= 4;
#endif
n = (uint8_t)U_1;
/* set up delay timer */
if (SetUpDelayTimer(n) == 0) return ESR; /* skip on error */
* measurement loop:
* - simulate AC by short positive and negative pulses
* - measure start voltage without DUT
* - measure pulse voltage with DUT
* - pre-charge DUT with a negative pulse of half length to
* to compensate voltage rise by positive charging pulse
* - 16 & 20 MHz MCUs seem to measure higher ESR values
ADC_PORT = 0; /* set ADC port to low */
ADMUX = Probe1; /* set input channel to probe-1 & set bandgap ref */
wait10ms(); /* time for voltage stabilization */
U_2 = 50; /* don't start with positive half-pulse */
U_4 = 0; /* start with a negative half-pulse */
n = 255; /* set loop counter */
while (n > 0)
wdt_reset(); /* reset watchdog */
* mitigate runaway of cap's charge/voltage
if (U_4 < 50)
/* charge cap a little bit more (negative pulse) */
/* set probes: GND -- probe-2 / probe-1 -- Rl -- 5V */
ADC_DDR = Probes.Pin_2; /* pull down probe-2 directly */
R_PORT = Probes.Rl_1; /* pull up probe-1 via Rl */
R_DDR = Probes.Rl_1; /* enable pull up */
wait2us(); /* wait half-pulse */
R_DDR = 0; /* disable any pull up */
R_PORT = 0; /* reset probe resistors */
if (U_2 < 50)
/* charge cap a little bit more (positive pulse) */
/* set probes: GND -- probe-1 / probe-2 -- Rl -- 5V */
ADC_DDR = Probes.Pin_1; /* pull down probe-1 directly */
R_PORT = Probes.Rl_2; /* pull up probe-2 via Rl */
R_DDR = Probes.Rl_2; /* enable pull up */
* forward mode, probe-1 only (probe-2 in HiZ mode)
* set probes: GND -- probe-1 -- Rl -- 5V / probe-2 -- HiZ
* get voltage at probe-1 (voltage at RiL)
ADC_DDR = Probes.Pin_1; /* pull down probe-1 directly to GND */
R_DDR = Probes.Rl_1; /* enable resistor */
/* run dummy conversion for ADMUX change */
ADCSRA = ADC_Mask; /* start conversion */
while (ADCSRA & (1 << ADSC)); /* wait until conversion is done */
/* real conversion */
U_1 = ADCW; /* save ADC value */
* forward mode, positive charging pulse
* get voltage at probe-2 (voltage at DUT, i.e. RiL + ESR)
ADMUX = Probe2; /* set input channel to probe-2 & set bandgap ref */
/* read ADC in the mid of a positive charging pulse */
ADCSRA = ADC_Mask; /* start conversion with next ADC clock cycle */
wait10us(); /* fixed pre-delay */
DelayTimer(); /* delay for pulse */
R_DDR = Probes.Rl_2; /* enable resistor */
wait2us(); /* first half-pulse */
/* S/H happens here */
#if CPU_FREQ < 8000000
wait2us(); /* second half-pulse */
#endif
R_PORT = 0; /* set resistor port to low */
R_DDR = 0; /* set resistor port to HiZ */
U_2 = ADCW; /* save ADC value */
* reverse mode, probe-2 only (probe-1 in HiZ mode)
* set probes: GND -- probe-2 -- Rl -- 5V / probe-1 -- HiZ
* get voltage at probe 2 (voltage at RiL)
U_3 = ADCW; /* save ADC value */
* reverse mode, negative charging pulse
* get voltage at probe-1 (voltage at DUT, i.e. RiL + ESR)
/* read ADC in the mid of a negatve charging pulse */
#endif
U_4 = ADCW; /* save ADC value */
* manage measured values
Sum_1 += U_1; /* positive pulse without DUT */
Sum_1 += U_3; /* negative pulse without DUT */
Sum_2 += U_2; /* positive pulse with DUT */
Sum_2 += U_4; /* negative pulse with DUT */
n--; /* next loop run */
* process measurements
if (Sum_2 > Sum_1) /* valid measurement */
* calculate ESR
* - ESR = U_ESR / I_ESR
* with U_ESR = (U2 or U4) and I_ESR = (U1 or U3) / RiL
* ESR = (U2 or U4) * RiL / (U1 or U3)
* - since we divide (U2 or U4) by (U1 or U3), we don't need to convert
* the ADC value into a voltage and simply desample the sums.
* - so ESR = Sum_2 * RiL / Sum_1
* - for a resolution of 0.01 Ohms we have to scale RiL to 0.01 Ohms
/* voltage across the DUT (raw value) */
Sum_2 -= Sum_1; /* subtract voltage at DUT's low side (RiL) */
/* ESR = Sum_2 * RiL / Sum_1 */
Value = (uint32_t)(NV.RiL * 10); /* RiL in 0.01 Ohms */
Value *= Sum_2; /* sum of raw values for voltage across DUT */
Value /= Sum_1; /* sum of raw values for voltage at RiL */
U_1 = (uint16_t)Value;
/* consider probe resistance */
if (U_1 > NV.RZero) /* larger than offset */
U_1 -= NV.RZero; /* subtract offset */
ESR = U_1; /* got result */
else /* offset problem or zero */
/* should only happen for large caps */
if (CmpValue(Cap->Value, Cap->Scale, 1000, -6) > 0)
ESR = 0; /* can't be less than 0 Ohms */
/* update Uref flag for next ADC run */
Cfg.RefFlag = ADC_REF_BANDGAP; /* update flag */
return ESR;
Because the "non valid" return value has changed, you also need to modify Show_Capacitor() in main.c and ESR_Tool() in extras.c. Simply change
if (ESR > 0)
into
if (ESR < UINT16_MAX)
That should support caps down to 10nF. The ESR values may differ a few percent for different MCU clocks because of the different test frequencies (-> Fourier series). Please let me know if the changes work for you.
