An eBay seller sent me an HC-05 (cheap Bluetooth module for AVR, www.hc01.com/en) by mistake. I wonder if it would be possible to use it to send some output from the TT to a smartphone for display. There is an Android app specifically for using the HC-05.
On the K firmware, you just need to enable the UART on the firmware and you are good to go,see attached pictures.
I use the serial output to log some measurement and I made a small Processing sketch to display the measurements on a PC monitor.
To simplify the code, I changed the firmware to send on the UART the line number of each text string and a "new_line" = ("\r\n") at the end of each line.
I posted some detail one year ago in the following message and I hope
Karl-Heinz will add this changes in the main firmware
https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/msg875362/#msg875362.
Now I fugured out how to wrap the text of the Selection menu...
If someone is interested I attached the custom firmware for the M12864 DIY Kit and the Processing sketch.
I'm also developing a small android app to log the measurements on a phone
If you improve the Processing sketch (at the moment it can handle correctly only some of the measurements), or you are developing an app, please share it so this can become a nice addition to this super useful tool.
Mauro
