Actually I have two identical units of the tester, one operative and one damaged in the process of repair (soon I will receive the components to repair it).
Once I have the second unit repaired I will proceed to install the firmware m, so I will have the best of both firmwares.
And I will try to add a rotary encoder even if I have to modify the box where I have it installed.
Can you recommend a rotary encoder as small as possible to ask for it on Ebay?
Also I will look at the file variables.h to try to translate it into Spanish in case I can support the project.
I attach a Spanish translation of the file langSPANISH.h of the version k with some modifications in the texts in the measurement of crystals of quartz and in the option meter of frequency for that appears like "Not available".
A greeting.
