Author Topic: $20 LCR ESR Transistor checker project  (Read 3907858 times)
edgard22, Feliciano and 40 Guests are viewing this topic.
Offline flywheelz
« Reply #2825 on: September 27, 2016, 05:40:46 am »
@packetbob,
Nice write up of your experience and your success story.  I like the simple platter you made for the little guy, neat  :-+
Is it possible you've mixed up the link to GM328x 16Mhz firmware?  I believe that unit has monochrome LCD and ours is AY-AT unit with TFT Color LCD.
Offline alte
« Reply #2826 on: September 27, 2016, 02:59:50 pm »
There is a case for the AY-AT on thingiverse; http://www.thingiverse.com/thing:1633951
It's simple but a good fit and protects your tester form dust when not in use.
All credit goes to the designer  :-+
Offline flywheelz
« Reply #2827 on: September 27, 2016, 10:20:37 pm »
I guess its good for those with makerbot/3d printer but I tried to order it and they want $25.33  :-- no thanks.  Better and cheaper $6.88 to get [this one] but do need to modify it a little like [this]  :-+
« Last Edit: September 27, 2016, 10:26:22 pm by flywheelz »
Offline packetbob
    • zappedmyself.com
« Reply #2828 on: September 28, 2016, 12:54:05 am »
You are correct...
I updated the link in my earlier post..
The firmware for the AY-AT that I used is at:
https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/msg1009936/#msg1009936
Thanks for catching that.....
« Last Edit: September 28, 2016, 01:01:45 am by packetbob »
The following users thanked this post: flywheelz
Offline indman
  • Country: by
« Reply #2829 on: September 28, 2016, 09:25:17 am »
Hi, friends! For a tester of DIY Kit "AY-AT" it is necessary to change in config_328.h  line
#define LCD_RES PD4 on
#define LCD_RES PD0
  According to the diagram of a tester the output 2 processors is connected to contact of RESET of the display.
The following users thanked this post: jm_araujo
Offline madires
  • A qualified hobbyist ;)
« Reply #2830 on: September 28, 2016, 09:49:07 am »
That makes sense, since the frequency counter requires T0, which is PD4 in case of the ATmega328. I'll update the Clones file.
Offline indman
  • Country: by
« Reply #2831 on: September 28, 2016, 10:00:02 am »
Some ST7735 displays will work if to leave a line without changes
#define LCD_RES PD4. But there are displays which will have only the white screen in case of switching on.
My friend who has the same tester faced such problem.  :)
Offline madires
« Reply #2832 on: September 28, 2016, 11:01:45 am »
Then we should keep "#define LCD_RES  PD0". If LCD_RES is set to PD4, which isn't connected to the LCD module, the pin doesn't contol anything, besides creating some additional heat in the bottom resistor of the frequency counter's input voltage divider. So setting PD0 would increase the run time of the battery ;)
Offline indman
  • Country: by
« Reply #2833 on: September 28, 2016, 11:12:31 am »
Very correct note! :)
Offline idwr
  • Country: id
« Reply #2834 on: September 29, 2016, 04:03:14 am »
I have AY-AT_ST7735   modul tester TFT.
an information in forum latest firmware:
mega328_color_kit_AY-AT_ST7735_trendy_1.24m
and we've tried, okay
but I have not found .....
DS1820 tester
IR tester
DHT11 tester
if anyone has already tried, firmware with DS/IR/DHT11 tester....?
thank you
Offline madires
« Reply #2835 on: September 29, 2016, 07:28:19 am »
Please download the source ( https://github.com/svn2github/transistortester/tree/master/Software/Markus ) and read the README file. The firmware doesn't support the two sensors, but an IR receiver module and several RC protocols.
Offline Gandalf_Sr
« Reply #2836 on: September 29, 2016, 04:11:56 pm »
I bought an already made GM328R from eBay which works but looks like it was made by a drunken Boy Scout on a Friday afternoon - all the components are mis-aligned.  Anyway it works.  I want to upgrade so a few quick questions:
1. Will the new firmware that madires just linked to (vn 1.25m I think), work on the GM2328R?
2. I have some 20 MHz but no 16 MHz Xtals, can I fit a 20 MHz Xtal and use the new (or another) firmware or would you recommend 16 MHz?
3. I just bought a TL866A programmer so I'm new to it, it starts to read the ATmega328 and then comes up with "read error code 31"; is this because the AVR is locked?
4. I think I can reprogram by erasing, then load the data and eeprom areas (as Intel hex), and then set the fuses, right?
Thanks for any help in advance.
BTW, I'm a self-employed hardware / PCB designer.  If someone sends me a schematic for the new circuit, I will design the PCB for the community.
« Last Edit: September 29, 2016, 04:15:02 pm by Gandalf_Sr »
If at first you don't succeed, get a bigger hammer
Offline madires
« Reply #2837 on: September 29, 2016, 04:46:22 pm »
Should work if it got a supported display (I'd guess it's a ST7565) and the 20MHz crystal is also fine with the m-firmware. Some clone vendors lock the MCU, which is plain stupid since the firmware is open source. And yes, you need to perform a "chip erase" to reset the lock bits.
Offline vinceroger
« Reply #2838 on: September 29, 2016, 04:51:12 pm »
i have this programmer as you say use intel hex for the files
This is the picture with the correct fuse settings for the programmer.
https://www.dropbox.com/s/zqacxby4ayngy2c/Fuses%20on%20TL866A.jpg?dl=0
Offline Gandalf_Sr
« Reply #2839 on: September 29, 2016, 05:37:05 pm »
I've posted a picture of mine, can someone please help me get the right hex files for the new vn m for a 20 MHz Xtal?
Thanks
Offline vinceroger
« Reply #2840 on: September 29, 2016, 05:42:17 pm »
Thanks
I have two of these exact testers one original firmwre 8mhz crystal one 16 mhz and v2 firmware i will attach the firmware i used but not sure if it supports the 20mhz crystal maybe stj can advise as its his firmware files
Offline stj
« Reply #2841 on: September 29, 2016, 06:03:13 pm »
the K firmware does not support 20MHz, the M (Madires) firmware does.
Offline Gandalf_Sr
« Reply #2842 on: September 29, 2016, 06:09:13 pm »
Thanks for all the help guys.  I probably need to place a Digikey order in the next day or so so I've added some 16 MHz Xtals to the cart then I'll have 8, 16 and 20 MHz options.
Offline fz
« Reply #2843 on: October 01, 2016, 03:19:36 am »
Hi everyone,
A great forum! I purchased an AY-AT clone of this tester from http://www.ebay.com/itm/182153844649 based on the recommendations here. It booted up fine after I put it together. I then did a dumb thing: I changed the frontcolor and it now doesn't display anything |O
I tried a few things, including setting the test to selftest mode, as suggested on the seller's the ebay site. But it was very hard to know what I was doing without the display:( My questions are 1) is there a way to reset the display settings on this thing, and 2) if not how can I get the display back?
Many thanks,
feng
Offline flywheelz
« Reply #2844 on: October 01, 2016, 03:32:08 am »
Try this with unit off.
  • Press and Hold for 2 to 3 seconds, unit should turn on and get into Menu.
  • Rotate to Left (counter-clockwise) 4 Clicks
  • Press down once
  • Rotate Left few clicks until you see red
  • Press down once to go to next color
  • Press and Hold when done.
Only other way is to reflash eeprom.
Update:  If above don't work, then try 5 clicks in step 2.  The idea is you enter the Fontcolor in the dark.
« Last Edit: October 01, 2016, 04:08:53 am by flywheelz »
The following users thanked this post: fz
Offline stj
« Reply #2845 on: October 01, 2016, 05:07:01 am »
sounds like the code needs a patch to prevent the background and forground from being set to the same value or even wihin a couple of points either way.
Offline milamber
« Reply #2846 on: October 01, 2016, 09:33:25 am »
How are your experiences with the acryl case?
http://www.ebay.de/itm/112108340467?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Is the ZIF socket lever still acceptably usable?
Offline vinceroger
« Reply #2847 on: October 01, 2016, 10:38:02 am »
I havnt got this case but i would modify it so you can get too the lever easily and also the smd test pads on the pcb.
Offline Pukker
« Reply #2848 on: October 01, 2016, 05:59:58 pm »
See my post 2673, I've modified the case a little bit to acces the lever and the SMD pad.
You can make an longer handle to the lever, but I didn't like that.
I like the case when modified.
There is room for a 9 Volt battery.
Maybe I make an SPI interface in the case.
Offline fz
« Reply #2849 on: October 01, 2016, 11:43:30 pm »
  • Press down once
Many thanks, Flywheelz, it worked on the first try :-+ 4 clicks gets you to frontColor.
