A pack of 16MHz crystals came today. Replace the 8 for 16 on my Color-kit AY-AT tester. The holes were a biatch to clean out for the new crystal.
When I plugged in the battery, the tester started up just fine. It seem to work normally with 8MHz fw build. Feels faster refresh/test times.
Next, I've flashed a 16MHz fw but not seeing any difference from 8MHz fw:-//.
Am I missing something?
Can I test the crystals with the tester?
Fuses are set to F7/D9/04. I know some people set efuse to 0xfc, but my atmega can't take that, 0x04 works.
Update:After more testing, with 8MHz fw and 16MHz xtal, the capacitance test values are doubled. With 16MHz fw they are reported correctly
