Author Topic: $20 LCR ESR Transistor checker project  (Read 3935537 times)
0 Members and 46 Guests are viewing this topic.
Online indman
  • Country: by
« Reply #9425 on: May 08, 2024, 11:45:04 am »
dosis_r, What frequency is the quartz set to in your clone? You need to find or configure firmware for the same frequency.
The following users thanked this post: dosis_r
Offline madires
  • A qualified hobbyist ;)
« Reply #9426 on: May 08, 2024, 12:22:46 pm »
If I'm not mistaken, dosis_r seems to run a firmware compiled for 8 MHz on an ATmega with a 16 MHz clock.
Offline Yuriy_K
  • Country: ru
« Reply #9427 on: May 08, 2024, 04:33:20 pm »
I got the firmware also from this forum and used an Atmega 328P MCU.
I hope friends on this forum can give me an explanation or teach me how to fix this problem..
This is my firmware, but you must indicate the name of the archive you installed.
It is necessary to find out the frequency indicated on the quartz, indicated by the red arrow. For example, I highlighted the incorrect values in Show data. What is not clear is the blue background, this is a BGR display, but it looks like 16 MHz quartz?
On displays released in 2022, the 16 MHz firmware did not work. You can try it on your display...
« Last Edit: May 09, 2024, 03:28:16 am by Yuriy_K »
Offline dosis_r
  • Country: id
« Reply #9428 on: May 10, 2024, 02:08:09 am »
I don't know sir, maybe is 16000MHz Xtal..
Because the component doesn't have a marking (only AG), I bought the ESR from local store in here.
Seller doesn't have response my message.  :(
Offline dosis_r
  • Country: id
« Reply #9429 on: May 10, 2024, 02:15:20 am »
Maybe sir, Because I just downloaded the firmware from this forum then tried it and it worked, only the capacitor reading was not correct. I can't choose an accurate firmware because my ESR doesn't have marking on Xtal component.. :-\
Offline dosis_r
  • Country: id
« Reply #9430 on: May 10, 2024, 02:52:16 am »
Hi Sir,
I want to thank you in advance, and sorry if I use your firmware without your permission first. I bought this ESR because the test results display were good and it all turned out to be your work.  :-+
I use the firmware with the name ST7735_RGB_en.zip and attached are some of the firmware that I have downloaded to try to get my ESR back on. Thanks for your new firmware and I will try it as soon as possible..  :)
« Last Edit: May 10, 2024, 07:42:55 am by dosis_r »
Offline Yuriy_K
  • Country: ru
« Reply #9431 on: May 10, 2024, 07:34:15 am »
This firmware has not been tested with your display, errors may occur. First you need to show the Selftest results and Show data. Using film capacitors 470 nF - 1000 nF and 10 nF - 20 nF for the resonant method of measuring inductances.
Offline dosis_r
  • Country: id
« Reply #9432 on: May 10, 2024, 11:07:15 am »
Okay sir,
I have tested the new firmware that you provided and the results are quite good, the firmware is able to read Capacitor :
1. 220nF (Mutimeter) = 215nF (ESR Meter)
2. 10nF (Multimeter) = 9.7nF (ESR Meter)
I haven't been able to test the 470nF-1000nF capacitor because it doesn't have a components, maybe tomorrow I can get it.
It's just that the previous firmware display (RGB) was what appeared when I first got this ESR Meter. The appearance is different from the BGR Firmware you provided.
Attached is the result of show data using your new firmware. Thank You..  :)
« Last Edit: May 10, 2024, 11:09:20 am by dosis_r »
Offline Yuriy_K
  • Country: ru
« Reply #9433 on: May 10, 2024, 11:24:22 am »
Now the readings are normal. You don't have to look for 470-1000 nF.
I now see that the RGB display, the colors are mixed up. You need to install this firmware...
« Last Edit: May 10, 2024, 11:39:32 am by Yuriy_K »
Offline horo
    • My GitHub Projects
« Reply #9434 on: May 11, 2024, 06:32:52 pm »
After surviving the April's Fool Day here's the real deal. Get your programmer ready and enjoy!
v1.52m
Please download at:
- https://github.com/madires/Transistortester-Warehouse/tree/master/Firmware/m-firmware
- https://github.com/kubi48/TransistorTester-source/tree/master/Markus (soon)
Also available at:
https://github.com/Ho-Ro/ComponentTester
Modified version for my AY-AT with 20 MHz xtal:
https://github.com/Ho-Ro/ComponentTester/tree/AY-AT_20MHz
Martin
Offline Jacon
« Reply #9435 on: May 12, 2024, 09:54:46 am »
Hi guys,
Sorry for such delay, but here it is - updated ISO 8859-2 Polish translation file
The following users thanked this post: madires
Offline horo
« Reply #9436 on: May 12, 2024, 05:57:18 pm »
v1.52m
- Added option to optimize the interrupt vector table to reduce firmware size (Makefile: OPTIMIZE_VECTORS, thanks to Viktor Klimkovich).
This option doesn't work correctly with my avr-gcc version 8.3.0, version 5.4.0 (the debian stable default), 7.3.0, and 13.2.0 work as expected.
This is what I get with avr-gcc-8.3.0:
.section .vectors,"ax",@progbits
  .global __vectors
  .func __vectors
__vectors:
    XJMP __init  // __vectors[0]
       0: 0c 94 23 0e jmp 0x1c46 ; 0x1c46 <__ctors_end>
    .altmacro
    .set i,1
    .rept 127   // __vectors[1..127]
      vector %i
      .set i,i+1
    .endr
       4: 0c 94 00 2e jmp 0x5c00 ; 0x5c00 <__bad_interrupt>
       8: 0c 94 00 2e jmp 0x5c00 ; 0x5c00 <__bad_interrupt>
       c: 0c 94 00 2e jmp 0x5c00 ; 0x5c00 <__bad_interrupt>
      10: 0c 94 00 2e jmp 0x5c00 ; 0x5c00 <__bad_interrupt>
      14: 0c 94 00 2e jmp 0x5c00 ; 0x5c00 <__bad_interrupt>
      18: 0c 94 00 2e jmp 0x5c00 ; 0x5c00 <__bad_interrupt>
      1c: 0c 94 00 2e jmp 0x5c00 ; 0x5c00 <__bad_interrupt>
      20: 0c 94 00 2e jmp 0x5c00 ; 0x5c00 <__bad_interrupt>
      24: 0c 94 00 2e jmp 0x5c00 ; 0x5c00 <__bad_interrupt>
      28: 0c 94 00 2e jmp 0x5c00 ; 0x5c00 <__bad_interrupt>
      2c: 0c 94 00 2e jmp 0x5c00 ; 0x5c00 <__bad_interrupt>
      30: 0c 94 00 2e jmp 0x5c00 ; 0x5c00 <__bad_interrupt>
      34: 0c 94 00 2e jmp 0x5c00 ; 0x5c00 <__bad_interrupt>
      38: 0c 94 00 2e jmp 0x5c00 ; 0x5c00 <__bad_interrupt>
      3c: 0c 94 00 2e jmp 0x5c00 ; 0x5c00 <__bad_interrupt>
      40: 0c 94 00 2e jmp 0x5c00 ; 0x5c00 <__bad_interrupt>
00000044 <__trampolines_end>:
while e.g. ver 13 gives:
  .global __vectors
  .func __vectors
__vectors:
00000004 <.Loc.1>:
    .altmacro
    .set i,1
      vector %i
       4: 0c 94 55 2e jmp 0x5caa ; 0x5caa <__bad_interrupt>
       8: 0c 94 55 2e jmp 0x5caa ; 0x5caa <__bad_interrupt>
       c: 0c 94 55 2e jmp 0x5caa ; 0x5caa <__bad_interrupt>
      10: 0c 94 55 2e jmp 0x5caa ; 0x5caa <__bad_interrupt>
      14: 0c 94 55 2e jmp 0x5caa ; 0x5caa <__bad_interrupt>
      18: 0c 94 55 2e jmp 0x5caa ; 0x5caa <__bad_interrupt>
      1c: 0c 94 fb 2d jmp 0x5bf6 ; 0x5bf6 <__vector_7>
      20: 0c 94 55 2e jmp 0x5caa ; 0x5caa <__bad_interrupt>
      24: 0c 94 55 2e jmp 0x5caa ; 0x5caa <__bad_interrupt>
      28: 0c 94 55 2e jmp 0x5caa ; 0x5caa <__bad_interrupt>
      2c: 0c 94 17 2e jmp 0x5c2e ; 0x5c2e <__vector_11>
      30: 0c 94 55 2e jmp 0x5caa ; 0x5caa <__bad_interrupt>
      34: 0c 94 55 2e jmp 0x5caa ; 0x5caa <__bad_interrupt>
      38: 0c 94 55 2e jmp 0x5caa ; 0x5caa <__bad_interrupt>
      3c: 0c 94 55 2e jmp 0x5caa ; 0x5caa <__bad_interrupt>
      40: 0c 94 05 2e jmp 0x5c0a ; 0x5c0a <__vector_16>
00000044 <Inductor_table>:
This change fixes the behaviour for ver 8.3.0:
diff --git a/gcrt1.S b/gcrt1.S
index 71689db..dad52e1 100644
--- a/gcrt1.S
+++ b/gcrt1.S
@@ -70,7 +70,7 @@
 .macro vector i
   .if (. - __vectors <= last_used_vector*4)
     .weak __vector_\i
-    .set __vector_\i, __bad_interrupt
+    // .set __vector_\i, __bad_interrupt
     XJMP __vector_\i
   .endif
 .endm
EDIT: After this "fix" I get:
  .global __vectors
  .func __vectors
__vectors:
    .altmacro
    .set i,1
      vector %i
      .set i,i+1
    .endr
       4: 0c 94 00 00 jmp 0 ; 0x0 <__vectors>
       8: 0c 94 00 00 jmp 0 ; 0x0 <__vectors>
       c: 0c 94 00 00 jmp 0 ; 0x0 <__vectors>
      10: 0c 94 00 00 jmp 0 ; 0x0 <__vectors>
      14: 0c 94 00 00 jmp 0 ; 0x0 <__vectors>
      18: 0c 94 00 00 jmp 0 ; 0x0 <__vectors>
      1c: 0c 94 00 2e jmp 0x5c00 ; 0x5c00 <__vector_7>
      20: 0c 94 00 00 jmp 0 ; 0x0 <__vectors>
      24: 0c 94 00 00 jmp 0 ; 0x0 <__vectors>
      28: 0c 94 00 00 jmp 0 ; 0x0 <__vectors>
      2c: 0c 94 d8 2d jmp 0x5bb0 ; 0x5bb0 <__vector_11>
      30: 0c 94 00 00 jmp 0 ; 0x0 <__vectors>
      34: 0c 94 00 00 jmp 0 ; 0x0 <__vectors>
      38: 0c 94 00 00 jmp 0 ; 0x0 <__vectors>
      3c: 0c 94 00 00 jmp 0 ; 0x0 <__vectors>
      40: 0c 94 ee 2d jmp 0x5bdc ; 0x5bdc <__vector_16>
Slightly different, but not an issue b/c also "__bad_interrupt" jumps to address 0:
00005c64 <__bad_interrupt>:
.global __bad_interrupt
.func __bad_interrupt
__bad_interrupt:
.weak __vector_default
.set __vector_default, __vectors
XJMP __vector_default
    5c64: 0c 94 00 00 jmp 0 ; 0x0 <__vectors>
This "fix" works with all my available avr-gcc versions 5.4.0, 7.3.0, 8.3.0, and 13.2.0
EDIT2: corrected the debian stable version (5.4.0)
« Last Edit: May 14, 2024, 06:59:37 pm by horo »
The following users thanked this post: madires, Fuzzy Star
Offline dosis_r
  • Country: id
« Reply #9437 on: May 13, 2024, 07:47:12 am »
Oke Sir, Thanks You..
Now my ESR is working again as it should...  :-DMM:-+
Thank you very much for your help and all the friends here... :)
Offline Shamzeen
  • Country: by
« Reply #9438 on: May 14, 2024, 08:13:29 am »
Hello everyone.
Who doesn't find it difficult, please compile the firmware for my device for quartz 8 MHz and 16 MHz, the interface language is English and Russian?
Offline Strateg58
  • Country: ru
    • https://www.eevblog.com/forum/register2/
« Reply #9439 on: May 19, 2024, 05:33:48 am »
Greetings to all. The LCR TC-1 v2.0 transistor tester has a U5 chip labeled AL816. Does anyone know what kind of chip it is?
« Last Edit: May 19, 2024, 05:35:32 am by Strateg58 »
Offline madires
« Reply #9440 on: May 19, 2024, 10:26:24 am »
That should be the SD6271 boost converter.
The following users thanked this post: Strateg58
Offline madires
« Reply #9441 on: May 19, 2024, 10:34:59 am »
I don't recognize your tester model. Do you have any more details?
Offline Shamzeen
  • Country: by
« Reply #9442 on: May 20, 2024, 12:19:59 pm »
The device is assembled according to this scheme
Offline madires
« Reply #9443 on: May 20, 2024, 01:16:26 pm »
That seems to be a clone of the AY-AT/GM328A. You can find a compiled k-firmware for 8 MHz at https://github.com/kubi48/TransistorTester-source/tree/master/trunk/mega328_color_kit.
Offline Shamzeen
  • Country: by
« Reply #9444 on: May 21, 2024, 05:12:05 am »
Yes, thanks, this firmware is working. But I also want to use your firmware. Should there be less than 100 here when compiling?
Offline madires
« Reply #9445 on: May 21, 2024, 09:09:39 am »
Yes, the firmware size shouldn't exceed 100%. Disable one or two features you don't need (e.g. SW_UJT) to reduce the size.
Offline horo
« Reply #9446 on: May 21, 2024, 09:33:06 am »
There's also the possibility to modify the linker options in the Makefile to shrink the code by some percent:
https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/msg5053126/#msg5053126
Offline horo
« Reply #9447 on: May 21, 2024, 04:16:39 pm »
Hello everyone.
Please find attached the AY-AT versions for 8, 16 and 20 MHz based on my setup for 1.52m.
Setup can be found in my repo:
Offline golub2017
  • Country: cs
« Reply #9448 on: May 22, 2024, 08:09:39 pm »
Hi I bought LCR T4, but is different then my old one, I want to change firmware, but board is v.4.1.3 and no pinot to hook programer.
Anyone see this board?
Thanks
Online Kim Christensen
« Reply #9449 on: May 22, 2024, 08:52:36 pm »
Your picture is too blurry. I can't see the writing on the MCU to even know what it is...
