Author Topic: $20 LCR ESR Transistor checker project  (Read 3907313 times)
tedris, Fuzzy Star, ddexd and 12 Guests are viewing this topic.
Offline Yuriy_K
  • Country: ru
« Reply #9175 on: February 16, 2024, 02:48:08 pm »
Some remarks about the measurements with the new CTester running 1.51m, after measuring some components and callibrated profile:
Examples of measuring capacitors on different firmware.
The following users thanked this post: Feliciano
Offline Feliciano
  • Country: ve
« Reply #9176 on: February 16, 2024, 04:41:21 pm »
Interesting: you are measuring the same capacitor on each CTester of each photo, right? because in each case the values are different, but on the same range, 'though. However, on the bottom right of the C100 photo it shows a value ten or twenty times higher than the others, like what I'm seeing now with 1.51m or 1.46m vs 1.13k.
So this (re)opens a new/old discussion: in the short term, the best known practice for configuration, to obtain a closer to reality value that gives us the idea on whether to replace or keep the DUT. And in the long term, whether there is something it could be optimized on the firmware
Note: We know that a real LCR Meter and a CTester use different methods for ESR assesment, but the difference is really high in some cases.
Offline madires
  • A qualified hobbyist ;)
« Reply #9177 on: February 17, 2024, 01:26:22 pm »
For low value capacitors it's better to use an LCR/ESR meter to measure the ESR. The k-firmware does a better job than the m-firmware in that regard, but the measurement error increases as the capacitance value decreases (for both firmwares, Karl-Heinz' documentation tries to explain this). There's another observation. The measurement algorithm delivers ESR results comparable to a 10kHz test signal of an LCR meter. With low capacitance values the ESR results seem to be increasingly converging to the real frequency of the measurement algorithm. For example, the m-firmware measures an ESR of about 5 Ohms for a 100nF film cap. An LCR meter shows 1 Ohm @ 1 kHz and 15 Ohms @ 120Hz.
The following users thanked this post: carl1961
Offline Feliciano
  • Country: ve
« Reply #9178 on: February 17, 2024, 08:34:39 pm »
I see, so in your opinion, the values currently measured by the m-firmware would be closer to the real life usage?
(For my use case, I normally work with switched power supplies).
Offline carl1961
« Reply #9179 on: February 18, 2024, 12:01:28 am »
Got JLC making von Boleslaw J. (boleslaw_43) Adapter_328-644_106_quartzw  there still in production, takes like 2-3 weeks before I get them. they or 5 on a part, so 25 total!  anyone who want's one, there free for the taking (20) just pay shipping (self return stamped envelope) C1 100nf,  R1 680 ohm,  C2 C3 22p
« Last Edit: February 24, 2024, 09:04:56 pm by carl1961 »
Offline Yuriy_K
  • Country: ru
« Reply #9180 on: February 18, 2024, 04:50:21 am »
For electrolytic capacitors, the difference in ESR readings is minimal. For film ones, the k-firmware readings are closest. Shown in the previous message. For ceramic capacitors, see for yourself...
« Last Edit: February 18, 2024, 06:16:14 am by Yuriy_K »
Offline willinsau
« Reply #9181 on: February 18, 2024, 05:19:19 am »
It Looks Good. Someone will sell this?
Offline Feliciano
  • Country: ve
« Reply #9182 on: February 18, 2024, 12:12:33 pm »
I suppose carl1961 is talking about a new version of the following adapter:
Adapter to upgrade the T-Tester with ATMEGA328 DIP28 to ATMEGA644 TQFP.
Idea and implementation by Boleslaw Jamroz from Poland,
I have only developed a circuit board for the cumbersome threading adapter
that simplifies the construction much ;-)
https://www.mikrocontroller.net/topic/transistortester-avr?goto=7398047#7381379
Offline madires
« Reply #9183 on: February 18, 2024, 12:20:19 pm »
The ESR values for low capacitances match an AC test signal of around 600 Hz, while for higher capacitances it's roughly 10 kHz. However, it's about comparing ESR vales at the same test frequency. Let's say you're repairing a buck converter running at 250 kHz, but your LCR meter's highest test frequency is 100 kHz. So you have to stick with the 100 kHz and compare a possibly bad electrolytic to a good one at that frequency.
Offline Feliciano
  • Country: ve
« Reply #9184 on: February 18, 2024, 12:53:04 pm »
Sure thing, but for my hobby I don't have a real LCR (high frequency) meter, so I'm using the pulse-train-based budget CTester clones (k-firmware, m-firmware) to get a rule of thumb on whether I shall replace or not a capacitor (most of times electrolitic for through-hole power supplies).
What got my attention is the tenfold difference estimation on each firmware branch, I haven't paid attention to that until know (as the modded m-firmware clones ran quickly from my hands). If you tell me you're trying to assimilate the values to those we would obtain from an LCR, that would be enough reasoning for me. But it you tell me "k-firmware does a better job on that regard" (moreover for lower capacitance, IIUC) I wonder why you chosed to go that path? Of course there should be reasons for that, but I also wonder why we would compromise for less accuracy if we know better, again, if that's the case.
Anyways, what about the Vloss and/or Iloss, if the values are accurate enough, we could judge based on that, or better on the the whole-picture, I suppose.
Offline carl1961
« Reply #9185 on: February 18, 2024, 02:11:26 pm »
Yes, he posted the grbl files for v106  the v108 is SMT crystal  page 32 along with the files for AY-AT   ComponentTester-1.51m_mod_files_for_AY-AT.zip  Page 31 for mega644_T7_AY_AT-Mod_v113k.zip  Lot's of good reading from the designers! a "must to read" to know better about these testers
Offline carl1961
« Reply #9186 on: February 18, 2024, 02:26:32 pm »
Nice case for the Latest NON removable atmega328p  I don't recommend buying these, I already had them before I adventured here. Buy a AY-AT kit and the .1% resistor and better MCP1702 5V chip
https://grabcad.com/library/transistor-tester-gm328a-2
« Last Edit: February 18, 2024, 02:31:32 pm by carl1961 »
The following users thanked this post: carrascoso, Obelix2007
Offline Feliciano
  • Country: ve
« Reply #9187 on: February 19, 2024, 12:45:54 pm »
FWIW, I ran the ESR test through a series of film Capacitors. The trend seems logical to me, what I was discussing was the differences (including slightly different slope).
« Last Edit: February 19, 2024, 11:05:23 pm by Feliciano »
The following users thanked this post: madires, Obelix2007, bffargo
Offline Yuriy_K
  • Country: ru
« Reply #9188 on: February 20, 2024, 07:38:06 am »
At the beginning of the work on upgrading the k-firmware, I compiled similar graphs. I hoped to find the dependence of ESR on capacitance, but when analyzing different types and models of capacitors, I realized that the idea was a dead end. A larger capacitance may have a higher ESR value. Here is an example of measurements for capacitors of 1 µF and 0.47 µF.
Offline Calambres
    • Piso-Tones
« Reply #9189 on: February 20, 2024, 12:44:08 pm »
Just got one of these:
https://www.ebay.com/itm/142849416622?var=441847192858
Seems to be a new variant of the AY-AT board (8MHz) with Atmel chip. Once calibrated it is very accurate... surprisingly accurate if you ask!
Offline Messtechniker
« Reply #9190 on: February 20, 2024, 01:17:11 pm »
It's always a good idea to have the micro socketed.
And a few spares around too. :horse:
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter, UT216C AC/DC Clamp Meter
Online BILLPOD
« Reply #9191 on: February 20, 2024, 01:47:57 pm »
That was the description of the one I got from Amazon, but mine has the ATP32F172K8T6 Chinese chip.   Same clear DIY case.
Offline Feliciano
  • Country: ve
« Reply #9192 on: February 20, 2024, 04:04:10 pm »
I read some post you made about this topic on mid-2022, and I tried to retake that line to prove a)there's a relationship, and more important to me, b)the difference between k-firmware and m-firmware approach.
For the first test, I selected some Capacitors from the same vendor, same batch, same voltage range (63V-100V), and the results were very nice IMO. For the second test, I took a blind approach (like the practical scenario for the repair shop): different vendors, different ages, different voltages, so I expected high discrepancies, which in fact ocurred but not enough to discard the idea IMHO. I suppose if somebody repeat the exercise with same brand and voltage Capacitors, a more evident trend can be obtained. Lastly, I notice the measurements differences between k-firmware and m-firmware, the values are more similar for this escenario (being the m the more consistent), but the slope of m-firmware is higher, confirming the observations of the first test.
« Last Edit: February 20, 2024, 04:12:40 pm by Feliciano »
Offline Calambres
    • Piso-Tones
« Reply #9193 on: February 20, 2024, 05:46:21 pm »
The kit includes 2% 1/8W resistors. I have checked them all and had to substitute some of them because they were beyond the 2% limit. I bet they're factory rejects to reduce costs...
The chip seems to be a legit ATMEL but nowadays who knows...
As I said in my previous port, once calibrated it is quite precise. I compared results with my DER DEE-5000 for resistors, capacitors and inductors and with my Peak Atlas DCA55 for semiconductors.
« Last Edit: February 20, 2024, 05:51:02 pm by Calambres »
Offline SA
  • Country: bd
« Reply #9194 on: February 21, 2024, 05:17:35 pm »
I fried my TC1 by charged capacitor. I have replaced the damaged components. The DIP MCU is also damaged. Is any firmware available for TC1 with atmega 328p? Attached picture is similar to my unit. I am not an expert, it would be great if there is hex file available.... :-+
Offline carl1961
« Reply #9195 on: February 22, 2024, 02:44:18 am »
Maybe start here, seems to be your model
https://www.eevblog.com/forum/testgear/tc1-lcr-meter-transistor-tester-fix/225/
Offline Yuriy_K
  • Country: ru
« Reply #9196 on: February 22, 2024, 09:26:28 am »
Some types of film capacitors have specific frequency characteristics. For comparison, I showed these characteristics in comparison with the readings of the k-firmware. The points on the graphs correspond to frequencies of 1,5,10,20,40,60,80,100 kHz
« Last Edit: February 22, 2024, 09:33:56 am by Yuriy_K »
Offline Feliciano
  • Country: ve
« Reply #9197 on: February 22, 2024, 11:21:10 am »
Absolutely, that's why is important -if we want to find trends- select same type of Capacitor, same Voltage range, and if possible, same vendor and batch (which I did for my first graph and not for the second).
« Last Edit: February 22, 2024, 11:31:55 am by Feliciano »
Online indman
  • Country: by
« Reply #9198 on: February 22, 2024, 03:01:37 pm »
I fully support that opinion. The use of a transistor tester to evaluate the quality of ceramic, film and other similar types is purely indicative and can very often misjudge such capacitors. There's no point in citing specs and graphs. It's easy enough to compare a few of the different types I listed above with a professional LCR meter to realize this. The difference between real ESR and tester readings can be 10-1000 times! Capacitance and ESR measurements a transistor tester are purely bonus in nature and are only good for monitoring ELECTROLYTIC capacitors. ;)
« Last Edit: February 22, 2024, 04:32:34 pm by indman »
The following users thanked this post: ayubando
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #9199 on: February 23, 2024, 02:08:56 am »
I personally find the tan(delta) or D (dissipation factor) a more convenient measure, as it is independent on the capacitance. Also, given it is specified in the datasheets, it becomes a more certain method to evaluate the state of a capacitor.
The following users thanked this post: indman
