Something for long, cold winter evenings:
v1.51m
- Changed GetThirdProbe() into convenience function UpdateProbes2() to reduce firmware size and adapted calls in various other functions (suggested by Viktor Klimkovich).
- Optimized DataStorage() and ManageAdjustmentStorage() to reduce firmware size (thanks to Viktor Klimkovich).
- Added option to slow down bit-bang SPI in case of a high MCU clock rate (SPI_SLOWDOWN, suggested by Viktor Klimkovich).
- Changed calculation of delay loop in IR_Detector() to support MCU overclocking (thanks to Viktor Klimkovich).
- Improved voltage drop algorithm in function LargeCap().
- Function LargeCap() takes now also negative zero offset into account.
- Changed self-adjustment to show the list of adjustment values only on success to prevent any misunderstanding.
- Corrected wrong value in E24 table (reported by siealex@EEVblog).
- POWER_OFF_TIMEOUT applies also to the main menu now (suggested by indman@EEVblog).
- Added French texts (thanks to moimem@EEVblog).
- Updated Brazilian Portuguese texts (thanks to wandows@EEVblog).
- Updated Polish texts #2 (thanks to Jacon@EEVblog).
- Corrected character 'q' in font_8x8_iso8859-2_hf.h (thanks to siealex@EEVblog).
- Updated Russian texts (thanks to indman@EEVblog).
- Updated Spanish texts (thanks to pepe10000@EEVblog).
Please downlaod at:
https://github.com/madires/Transistortester-Warehouse/tree/master/Firmware/m-firmware-
https://github.com/kubi48/TransistorTester-source/tree/master/Markus
