Okay, I couldn't find a AVRDudesshell2019, so I just installed AVRDUDESS 2.14. It successfully and reliably sets the fuse bits - I can set and read them as you showed now. However, the fault still persists even with the fuse bits set as you showed. How do I change the fuses to try to use the internal clock rather than the crystal?
