I have two of these component testers:
#1: The one my UART enquiry was about (ST7565 LCD - gorgeous green screen)
#2: A "Fish8840" type tester, colour LCD, in a black case
On tester #2 (Fish8840), the ". . ." when it's testing the component is animated with growing periods ("." ". ." ". . ." etc) and also animates over serial. On tester #2, it is a static ". . ." symbol, which is fine on the LCD, but shows a non-printing characted over serial (attached). Any ideas how I can animate the ". . ." on tester #1?
@@ Also, you may have surmised, I got serial working on tester #2 (Fish8840) but I don't like this unit that much - it blew the "Z14" 3.3v reference when I first flashed a new firmware, and... well, I don't use it.
@@ Error? @@
Unit #1 (green screen, LCR-T4) complains with the message below, after each test when I give a long press for a subsequent test:
"Not calibrated!
For calibration clamp
the 3 pins together
and start with
the key. Acknowledge
the self-test with
the key within 2s.
Disconnect pins after
the message
"isolate Probe!" is
shown. Software and
documentation is at
svn://
mikrocontroller.
net/transistor tester "
