May I bother you with a new version of the m-firmware?
v1.37m:
- Fixed error in DS18B20_Tool() when ONEWIRE_IO_PIN is enabled (reported by Bohu).
- Fixed issue with display of error message on color displays when the watchdog is triggered.
- Added new tool: event counter (HW_EVENT_COUNTER, suggested by Bohu).
- Changed the basic frequency counter to use TestKey() for user feedback.
Exit counter by two short key presses (was single press).
- Added option to show reverse hFE for BJTs (SW_REVERSE_HFE, suggested by
towe96@EEVblog). Also added "h_FE_r" command to remote command option.
- Added bitclock setting (BITCLOCK) for avrdude in Makefile (suggested by Bohu).
- Resolved issues with TRIAC detection in case of too high I_GT in Q3 or too high I_H (I_GT issue reported by petroid).
- Moved texts Tester_str, PWM_str, Hertz_str and CTR_str to language specific header files (suggested by indman@EEVblog).
- Changed output of frequency values to use common unit string instead of of split "H" and "z".
- Added option to display key hints (UI_KEY_HINTS), currently just "Menu/Test" (suggegsted by carrascoso@EEVblog).
- Updated Polish texts (thanks to szpila@EEVblog).
- Updated Russian texts (thanks to indman@EEVblog).
- Updated Spanish texts (thanks to pepe10000@EEVblog).
Download the latest version at
https://github.com/madires/Transistortester-Warehouse/tree/master/Firmware/m-firmware.
