Author Topic: $20 LCR ESR Transistor checker project  (Read 3953885 times)
0 Members and 14 Guests are viewing this topic.
Offline daemon123
  • Country: pk
« Reply #5800 on: August 17, 2019, 02:59:30 pm »
Slightly, but PE (especially PE0 and PE1) should be in HiZ mode by default. Or try to lift the two pins.
Lifting pin 3 & 6 did the trick,
its running now but its dead slow, the initial setup is running but it stuck on capacitor test.
its dead slow
below is flash log with fuses
avrdude -c avrisp -b 19200 -p m328pb -P COM7 -U flash:w:TransistorTester.hex:a -U eeprom:w:TransistorTester.eep:a -v
avrdude: Version 6.3-20171130
         Copyright (c) 2000-2005 Brian Dean, [url]http://www.bdmicro.com/[/url]
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr\etc\avrdude.conf"
         Using Port                    : COM7
         Using Programmer              : avrisp
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328PB
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel AVR ISP
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.05s
avrdude: Device signature = 0x1e9516 (probably m328pb)
avrdude: safemode: lfuse reads as F7
avrdude: safemode: hfuse reads as D9
avrdude: safemode: efuse reads as F4
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "TransistorTester.hex"
avrdude: input file TransistorTester.hex auto detected as Intel Hex
avrdude: writing flash (29732 bytes):
Writing | ################################################## | 100% 33.39s
avrdude: 29732 bytes of flash written
avrdude: verifying flash memory against TransistorTester.hex:
avrdude: load data flash data from input file TransistorTester.hex:
avrdude: input file TransistorTester.hex contains 29732 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 19.04s
avrdude: verifying ...
avrdude: 29732 bytes of flash verified
avrdude: reading input file "TransistorTester.eep"
avrdude: input file TransistorTester.eep auto detected as Intel Hex
avrdude: writing eeprom (857 bytes):
Writing | ################################################## | 100% 42.34s
avrdude: 857 bytes of eeprom written
avrdude: verifying eeprom memory against TransistorTester.eep:
avrdude: load data eeprom data from input file TransistorTester.eep:
avrdude: input file TransistorTester.eep contains 857 bytes
avrdude: reading on-chip eeprom data:
Reading | ################################################## | 100% 3.57s
avrdude: 857 bytes of eeprom verified
avrdude: safemode: Fuses OK (E:F4, H:D9, L:F7)
avrdude done.  Thank you.
its on default 8mhz crystal and running this firmware
https://github.com/svn2github/transistortester/blob/master/Software/trunk/mega328_T4_v2_st7565/
« Last Edit: August 17, 2019, 03:02:22 pm by daemon123 »
Offline madires
  • A qualified hobbyist ;)
« Reply #5801 on: August 17, 2019, 03:48:44 pm »
I've checked the clock settings for the 328PB and it doesn't have the full swing crystal option anymore. So you have to set the clock source to low power crystal, i.e. l-fuse should be ff.
The following users thanked this post: daemon123
Offline daemon123
  • Country: pk
« Reply #5802 on: August 17, 2019, 05:08:49 pm »
changed the fuse settings, but no change, should i reflash the firmware ?
avrdude -c avrisp -b 19200 -p m328pb -P COM7 -U efuse:w:0xF4:m -U hfuse:w:0xD9:m -U lfuse:w:0xFF:m
avrdude: reading input file "0xF4"
avrdude: writing efuse (1 bytes):
Writing | ################################################## | 100% 0.02s
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xF4:
avrdude: load data efuse data from input file 0xF4:
avrdude: input file 0xF4 contains 1 bytes
avrdude: reading on-chip efuse data:
Reading | ################################################## | 100% 0.01s
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0xD9"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xD9:
avrdude: load data hfuse data from input file 0xD9:
avrdude: input file 0xD9 contains 1 bytes
avrdude: reading on-chip hfuse data:
Reading | ################################################## | 100% 0.02s
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xFF"
avrdude: writing lfuse (1 bytes):
Writing | ################################################## | 100% 0.03s
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xFF:
avrdude: load data lfuse data from input file 0xFF:
avrdude: input file 0xFF contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude: safemode: Fuses OK (E:F4, H:D9, L:FF)
Offline madires
« Reply #5803 on: August 17, 2019, 06:04:18 pm »
No need to program the same firmware again. Usually the main cause for a slow tester is the CKDIV8 bit. When set the clock is divided by 8, but with l-fuse set to ff CKDIV8 is disabled. You could try to switch the clock source to the internal RC oscillator by setting l-fuse to e2 (just for testing if there's a problem with the crystal oscillator).
Offline daemon123
  • Country: pk
« Reply #5804 on: August 17, 2019, 06:14:55 pm »
No change, still dead slow
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avrdude.conf"
         Using Port                    : COM7
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: safemode: lfuse reads as E2
Writing | ################################################## | 100% 33.30s
Reading | ################################################## | 100% 19.14s
Writing | ################################################## | 100% 42.31s
Reading | ################################################## | 100% 3.46s
avrdude: safemode: Fuses OK (E:F4, H:D9, L:E2)
will try to install another crystal tomorow,
could it be a bad chip ?
or the firmware is not for 8mhz ?
Offline madires
« Reply #5805 on: August 17, 2019, 07:41:52 pm »
Since the internal RC oscillator doesn't resolve the issue the crystal should be fine. And the firmware is compiled for 8 MHz. CFD (Clock Failure Detection) switches the clock to 1MHz (internal RC plus divider) in case of a problem with the external clock or crystal, but CFD is disabled (e-fuse f4). Still, there's something wrong with the clock or clock prescaler.
Offline 001
  • Country: aq
« Reply #5806 on: August 18, 2019, 04:23:55 pm »
It is so old tread  :)
Great works and projects. And I see bunch of forks  :-+
But how I can start TT in 2019?
What fork is actual/progressive/usable now?
I`m gonna build TT with Arduino nano (https://www.ebay.com/itm/3pcs-x-Nano-V3-module-ATMega328-P-CH340G-16MHz-mini-USB-compatible-Arduino-D7-SF/323414472916?epid=11022866083&hash=item4b4d0138d4:g:neoAAOSw5sBbgfy8) and 2.9" 128*64 display since my eyes really needs LARGE pic (https://www.ebay.com/itm/128x64-LCD-Module-Display-LCM-ST7920-Controller-Paraller-Serial-white-on-Black/291836077918?hash=item43f2c9275e:g:sm0AAOSwj2Za1uv6)
Is it good way?
Offline Fuzzy Star
« Reply #5807 on: August 18, 2019, 06:08:30 pm »
...I see bunch of forks  :-+
You can start by reading the docs:
1. https://github.com/madires/Transistortester-Warehouse/blob/master/Documentation/
2. 'Readme' and 'changes.txt' files inside the 'ComponentTester-1.36m.tgz' from
   https://github.com/madires/Transistortester-Warehouse/tree/master/Firmware/m-firmware
The following users thanked this post: 001
Offline 001
  • Country: aq
« Reply #5808 on: August 18, 2019, 06:54:54 pm »
Thanx!  :-+
Is hardware still same?
Offline Fuzzy Star
« Reply #5809 on: August 19, 2019, 12:59:05 am »
Docs will answer almost all the questions. But yes, the circuit is still the same, the one in the .pdf document.
Offline 001
  • Country: aq
« Reply #5810 on: August 19, 2019, 07:18:49 am »
Thanx
But I have stupid question
How to program 16MHz (Arduino) instead 8Mhz quarz?
Offline Fuzzy Star
« Reply #5811 on: August 19, 2019, 06:55:16 pm »
Search '16MHz' in this thread.
Also (with a translator): https://www.mikrocontroller.net/topic/248078
Offline SirAlucard
« Reply #5812 on: August 21, 2019, 08:56:45 pm »
So after reading through lots of posts and trying to figure out how to go about updating the firmware on the Transistor Checker that I have, I finally gave in and figured I'd ask for a little assistance.
The specific one I have is this. https://www.ebay.com/itm/2019-Version-Transistor-Tester-LCR-Diode-Capacitance-ESR-meter-Signal-Generator/182678167951?ssPageName=STRK%3AMEBIDX%3AIT&var=485227022401&_trksid=p2057872.m2749.l2649
It looks like the AY-AT one except it says XR-116 at the top.
I can't for the life of me figure out what version this is. The buffer for the screen is a CD4050bm, Just not sure if it is a ST7735 Display, nor do I know the correct config for the firmware for this. Then to top that off if I need to set the correct fuses. So yea I keep searching, but with so many clones it's hard to make sure I have the correct one.
« Last Edit: August 22, 2019, 04:01:29 am by SirAlucard »
Offline Abacab
« Reply #5813 on: August 22, 2019, 08:38:47 am »
Thats the AY-AT( same as mine) , the screen is identical as well right down to the J1 symbol next to the pins so its the standard ST7735 Display.
The following users thanked this post: SirAlucard
Offline 001
  • Country: aq
« Reply #5814 on: August 22, 2019, 09:25:08 am »
Sorry again
Is MK-328 firmware compartible with some other clones?  :-//
Offline madires
« Reply #5815 on: August 22, 2019, 11:19:17 am »
Possibly, if the other clone has the same display (ST7565), MCU (328 at 8MHz), pin assignment and hardware options.
Offline 001
  • Country: aq
« Reply #5816 on: August 22, 2019, 11:42:23 am »
What I need to drive it to 16MHz properly?
Offline ledtester
« Reply #5817 on: August 22, 2019, 12:49:38 pm »
I don't know if this has been mentioned already, but I just found a huge compilation of photos, firmwares and schematics of a large number of transistor tester implementations.
If you have a look at this video starting at the 5 minute mark you'll see the directory structure of this compilation being traversed:
https://youtu.be/efHyRkTYLrE?t=5m
The URL for the archive is mentioned in the video description: https://yadi.sk/d/j7lZdKsPrwTq4Q
Once you download the archive, look in the Все прошивки directory.
Edit: You don't have to download the archive - you can browse it from that web page.
« Last Edit: August 22, 2019, 01:05:28 pm by ledtester »
Offline 001
  • Country: aq
« Reply #5818 on: August 22, 2019, 01:02:56 pm »
It looks like some russian trojan depository, isn`t it?  :-//
Foreign files can get to your Yandex.Disk if you log in to someone else’s mobile device. In this case, when startup is enabled, files from the device will be downloaded to Yandex.Disk.
You can stop downloading other people's files to your Yandex.Disk in the following ways:
Log out on all devices
To prevent other people's files from falling onto your Yandex.Disk, exit Yandex.Disk on all devices.
« Last Edit: August 22, 2019, 01:08:43 pm by 001 »
Offline madires
« Reply #5819 on: August 22, 2019, 01:09:42 pm »
A 16MHz crystal and a small change in the Makefile (or alternatively the precompiled 16MHz firmware from that russian trojan depository ;)).
« Last Edit: August 22, 2019, 01:21:36 pm by madires »
Offline indman
  • Country: by
« Reply #5820 on: August 22, 2019, 04:03:17 pm »
I already several times placed the reference to the archive with firmwares placed in the Russian storage https://yadi.sk/d/yW8xa5NJgUo5z
This archive is brought together personally by me and does not contain any viruses.
The person who showed the video just copied results of my work.  :palm:
« Last Edit: August 22, 2019, 04:05:42 pm by indman »
The following users thanked this post: bitseeker, ledtester, Fuzzy Star
Offline madires
« Reply #5821 on: August 22, 2019, 05:17:41 pm »
Yep, indman is the creator of that great collection of images, schematics and firmwares of the various clones.
The following users thanked this post: elecdonia
Offline SirAlucard
« Reply #5822 on: August 22, 2019, 06:08:13 pm »
Thank you for verifying that, that makes it easier to go through the config files for compiling. I was just being thrown through a loop cause the LCD didn't have any marks on it at all, and the K color firmware while working didn't quite fit into the LCD properly.
There really needs to be a post explaining where all the different measurement points are for calibrating and changing the calibration settings. (if there isn't already 233 pages is a lot to read through)
EDIT: So I finally got something to show up on my tester, it loads and verifies v1.36, however whenever I test anything it just shows
Battery?
2: 3mV
I have no idea what that is suppose to mean, but it's not testing any components.
« Last Edit: August 22, 2019, 08:09:13 pm by SirAlucard »
Offline madires
« Reply #5823 on: August 22, 2019, 08:43:18 pm »
That means the tester has tried to discharge whatever might be connected and the voltage at probe pin #2 stays at 3mV. Therefore it  assumes a battery or other power source. If the self-adjustment doesn't help you could increase the threshold CAP_DISCHARGED.
Offline SirAlucard
« Reply #5824 on: August 23, 2019, 03:10:27 am »
Alright, at first it started working, set the mv from 3 to 5 just in case, at first when nothing was connected I was correctly getting No Component which was expected. Then when testing a NPN Transistor it correctly identifies. It also worked correctly with a Mosfet. However when I place a 680nF Capacitor across pins 1-3 the thing just shuts down. After that when I removed everything from the tester it now shows up a 29pF Capacitor across 1-2 with nothing being connected.
Also what setting pauses the information screen after it pulls the information? Doesn't seem to sit on it long enough before it tries testing again.
