Author Topic: $20 LCR ESR Transistor checker project  (Read 3907291 times)
Fuzzy Star, ddexd, tedris and 8 Guests are viewing this topic.
Offline Hydrawerk
« Reply #450 on: June 03, 2014, 05:02:46 pm »
Yes, the latest firmware brings a special function in menu.
Offline intrax
« Reply #451 on: June 03, 2014, 06:10:04 pm »
Probably only working on atmega328… any link to a suitable model on ebay?  Thanks.
Offline madires
  • A qualified hobbyist ;)
« Reply #452 on: June 03, 2014, 06:14:59 pm »
Yep! Take any clone with an ATmega328 and flash the latest firmware. Both firmware branches (k and m) support in circuit capacitance and ESR checks.
Offline intrax
« Reply #453 on: June 03, 2014, 06:19:48 pm »
Any ? I do like the graphics display's… ;D
Offline robimarko
  • Country: hr
  • High Shool electronics hobbyst
« Reply #454 on: June 03, 2014, 08:27:50 pm »
I am looking to buy this one:http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=281314227233&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en
I need esr and capacitance measurment really often and i dont have money for a standard meter.
Can that version be updated with latest firmware?
And can you link some versions of firmware?
Offline madires
« Reply #455 on: June 03, 2014, 08:31:11 pm »
The Wumpus will get you  ;)
Offline neslekkim
  • Country: no
« Reply #456 on: June 03, 2014, 08:34:09 pm »
I guess you should ask the seller for the firmware source before buying those versions.. and find out if the icsp port is available for firmware uploads. ( I have newer found better pictures of these, showing the backside etc)
Offline eevbstedt
« Reply #457 on: June 03, 2014, 08:50:33 pm »
The description reminds me of the last one I bought.
'Latest Firmware' they said.
'What version is that?', I asked.
'The latest!', they said.
Turns out their definition of latest is 1.07k.  =/
Offline robimarko
  • Country: hr
« Reply #458 on: June 03, 2014, 08:59:28 pm »
That version is just an example,i sent a message to seller.
But most likely i will have to buy standard socketed 328 version with 16x02 lcd
Somebody got a recommendation?
« Last Edit: June 03, 2014, 09:03:38 pm by robimarko »
Offline madires
« Reply #459 on: June 03, 2014, 09:36:37 pm »
That clone uses a graphics LCD which requires some custom firmware modifications.
The latest and greatest is available at http://www.mikrocontroller.net/svnbrowser/transistortester/Software/ ('trunk' for the k-firmware and 'Markus' for the m-firmware).
« Last Edit: June 03, 2014, 09:38:30 pm by madires »
Offline AintBigAintClever
« Reply #460 on: June 03, 2014, 10:15:23 pm »
I bought http://www.ebay.com/itm/190949271460 which came with 1.10k firmware and the extra menus.
Main IC is a socketed 328.
« Last Edit: June 03, 2014, 10:21:38 pm by AintBigAintClever »
Offline neslekkim
  • Country: no
« Reply #461 on: June 03, 2014, 10:27:54 pm »
did you take some pictures of its inside?
Offline robimarko
  • Country: hr
« Reply #462 on: June 04, 2014, 07:12:03 am »
And off course seller does not send it to Croatia
« Reply #463 on: June 04, 2014, 10:36:30 pm »
Try this one, then. Looks identical, my guess is that the insides will be, too. Croatia not on the postal exclusions this time.
www.ebay.com/itm/181109931348
Pictures of the inside of mine attached.
Offline neslekkim
  • Country: no
« Reply #464 on: June 05, 2014, 07:39:14 am »
looks good.. Strange that nobody adds the programming headers :(
« Reply #465 on: June 05, 2014, 10:41:45 am »
Keeps the cost down I suppose. Why spend a few pence on a header when you can just NOT do it instead? Besides, if the IC is socketed it can be removed for programming.
Offline neslekkim
  • Country: no
« Reply #466 on: June 05, 2014, 10:44:19 am »
the header I can solder myself, but the pinout.. holes.. are those really expensive ? :)
Offline madires
« Reply #467 on: June 05, 2014, 11:11:09 am »
The cap for buffering AREF is missing (C1 in your case). By adding a 1nF ceramic cap you could stabilize the reference voltage of the ADC.
Offline intrax
« Reply #468 on: June 05, 2014, 05:09:55 pm »
Any links to a version including header?  O0
I have not seen one,  which one is best for in circuit testing ?
Offline retrolefty
« Reply #469 on: June 05, 2014, 06:07:49 pm »
 One problem attempting to use any ICSP is that the chip has external components wired to pins (I don't yet have a schematic so others would have to check for you) so they may very well interfere with the external programmer operation.
Offline madires
« Reply #470 on: June 05, 2014, 08:45:30 pm »
Most clones without an enclosure got the pads for the ISP header (hidden below the LCD module).
Offline madires
« Reply #471 on: June 05, 2014, 08:50:11 pm »
No worries, it's designed to work fine.
Offline Hydrawerk
« Reply #472 on: June 06, 2014, 09:52:26 pm »
My component tester is almost finished so I made a video. The front panel is under construction.
Well, there are many such videos on youtube. Nothing new really.
Offline robimarko
  • Country: hr
« Reply #473 on: June 07, 2014, 04:05:30 pm »
At end i bought this one
http://www.ebay.com/itm/281206556098?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
It has socketed DIP Atmega328 so even if it has old firmware revision i can flash it to latest with my arduino
Offline eevbstedt
« Reply #474 on: June 08, 2014, 01:50:56 pm »
That looks the same at the last one I got but is a different seller.  Ask them what version of firmware it comes with.  :)
