carrascoso, valcher, Melt-O-Tronic, tedris and 18 Guests are viewing this topic.
Sorry, I don't provide compiled firmware because there are too many different hardware versions. The links for the latest firmware versions:- k-firmware: https://github.com/svn2github/transistortester/tree/master/Software/trunk- m-firmware: https://github.com/svn2github/transistortester/tree/master/Software/Markus
Computers have this awesome ability called "search".
Get the schematic, grab a DMM and start checking
Possibly wrong fuse settings (CKDIV8 set/programmed).
Is the ATmega write protected (lock bits set)?
I have tested the voltages in the circuit and i had 0.2 volts on the out pin of ht7550 so i removed it and tried with 78L05 (thats what i had in my workshop) and it works. So 7550 worked for 2 seconds and died
Hi Guy'sI just purchased 2 of the AY-AT testers (1 kit, 1 assembled) and am going to install some better components. 680ohm 0.1%470kohm 0.1%LM4040 2.5v refMCP1702 5v regI have also ordered 4 extra ATMEGA328 chips so I can try different FW versionswithout overwriting original. (And to have spares)Can I also install a 16mhz crystal with stock firmware or will I have to reflash.Will stock firmware work with a 16mhz crystal???Anything else to replace to improve accuracy?Thanks
AVR Memory Usage----------------Device: atmega328Program: 36136 bytes (110.3% Full)(.text + .data + .bootloader)Data: 257 bytes (12.5% Full)(.data + .bss + .noinit)EEPROM: 882 bytes (86.1% Full)(.eeprom)
Is pd6 supposed to have power the whole time? My wont stay on unless i hold the button down..
