Hi.
I'm having some problems with the latest firmware revisions k (722 and 723) in measuring medium-low resistors value with my LCR-T4-H testers.
However with 729 and previous revisions work perfectly.
I attached some photos of the problem in question.
Is someone else going on?
Thank you and greetings.
Hi, after much research I think I have found the problem of measurement error in low value resistors in my LCR-T4-H.
It all started when I installed a voltage regulator MCP1702T-5002E more precise than the 78L05 and replaced the two diodes 1N4148 with an AMS1117-3.3v.
At first and with the old firmwares worked well, but with the most modern fimwares began to fail.
The problem seems to lie in the filtering of the main voltage of 5v for these LDO, in a Russian forum I saw a similar problem of measuring quartz crystals with nothing fitted in the zocalo ZIF, and applying the proposed solution to my tester has been Corrected said measurement of resistances of low value.
The solution consists in adding 3 capacitors of 100nF to the power and the reset of the Atmega328.
Attached two photos, one of the Russian solution and another of the capacitors I have put in my tester.
A greeting.
