Thought i'd open my MK-328 and put some pictures up.
Thanks.
Differences with mine are, Green PCB but seems decent quality, no EZM Studios logo on the casing or inside, but exactly the same PCB layout and components.
Looks like a clone of a clone. Regardless, I still find this unit the best looking and well thought out.
Its easy to replace the ZIF board. Build quality seem top notch and its design to be able to take some beating
About to fit a 16mhz Crystal and debating fitting a rotary encoder...
Upgrading the xtal is nice and easy. As for the encoder, I think its useful if you plan spend a lot of time in Freq/PWM Gen menus, for everything else a switch does a superb job.
Yeah I'd say it's a clone, but they are all pretty much clones of something so not bothered, PCB is an exact copy, same case, sticker fonts are identical and markings comparing it with another,
so who knows they might all even come out of the same place. Cost me £17 delivered with the ZIF, a lot of listings didn't have a ZIF included which I wanted.
I'll put a the 16mhz in when I get chance, loaded up the makefile today to have a play, will flash it when I fit the crystal.
Nah won't be using the frequency stuff on it, I can manage with the press and hold for the button, just always a case of upgraditis and tinkering, if I had an encoder here I'd put it in but not buying one just for that.
Not sure whether to go K or M firmware though, did see a post on here a while back with differences but I can't find it now
Screenshots of both firmwares I have been looking for too.
