andreab, carrascoso and 13 Guests are viewing this topic.
i found the top image, but no underside shot.
Quote from: stj on June 29, 2016, 03:46:40 ami found the top image, but no underside shot.https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/msg964111/#msg964111
Actually there are some Chinese $20 LCR testers that come with adapter for SMT parts for a long while but not as well done and integrated as the russian units.
wrong kit - that's the GM328R from EZM studio, i'm looking for the TFT kit with the red pcb.
that's what i was after - thanks.i wanted to see where the smd protection diodes were fitted.i also see a big space along the top edge - perfect for a 10pin programming header - perfect.well almost - they should have included it in the design along with a 16MHz crystal.
Quote from: all_repair on June 22, 2016, 12:58:05 pmActually there are some Chinese $20 LCR testers that come with adapter for SMT parts for a long while but not as well done and integrated as the russian units.They do look well constructed - have you bought a russian kit, or from that seller?
I would like to see the newer versions with color settings too
Got my M328-KIT-CTFT working after getting a replacement M328p IC.Indeed, they used the older 1.12k firmware.I would like to see the newer versions with color settings too Here some pictures I took when I got the kit.
I was sent these three files, they are instructions, schematic and parts location. - I have not yet verified the schematic matches the board.
Quote from: Willem52 on June 30, 2016, 09:57:11 amI would like to see the newer versions with color settings too Hi, friends! Karl-Heinz Kubeller made new revision of a firmware of SVN 681 for a clone of M328KitTFT which allows to set up font color and back color through the menu.
given the present space situation,i wonder how much bytes extra are needed for the colour display.
