Author Topic: $20 LCR ESR Transistor checker project  (Read 3875116 times)
NikolaSoft and 13 Guests are viewing this topic.
Offline madires
  • A qualified hobbyist ;)
« Reply #1250 on: September 18, 2015, 04:31:41 pm »
I need help guys in figuring out whats wrong, i have one of these LCR ESR Transistor checker with case, very handy gadget, till one day i accidentaly dropped it, screen cracked so i looked for a replacement 12864 lcd module, bought a bigger size lcd bec i cant find exact size, and when i hooked it up to the characters are inverted, photos attached, thanks in advance...
You need to compile the firmware with options set to match your display. There are options to flip x and y.
Offline papabol_24
« Reply #1251 on: September 18, 2015, 04:59:45 pm »
Oh :), thanks very much @madires, ive been doing back reading & thanks to your hard work guys there are firmwares that i can try to work on to, just woried though bec my minipro TL866A (Converted from CS to A Thanks to this forum :-+) cannot read this through ICSP, gonna give it a try tomorow, Thanks again  :)
Offline tom666
  • Country: sk
    • Slovak discussion forum - AVR Component Tester (RLC/ESR & Semiconductors Tester)
« Reply #1252 on: September 19, 2015, 10:15:00 am »
FYI
Hello friends,
recently, the author of the software (Karl-Heinz Kübbeler (kubi48)) working intensively on its improvement :clap: :-+ Proof of this is a new function that extend the testing of small capacitors (<100pF) by use of a sampling mode for the ADC converter. Extend the resolution of measurement is about 0.01pF. To enable this new functionality is necessary to enable in the Makefile this setting "WITH_SamplingADC = 1". It is designed only for M328 and higher MCUs.
Bye
Tomas
Offline papabol_24
« Reply #1253 on: September 19, 2015, 11:34:42 am »
Hello guys, i just flashed my Fish8840 with case tester with "ComponentTester-trendy-1.18m" by Markus, just as @madires said that i have to look for options how to flip the display to work with my LCD module replacement, so i edited config.h, after flashing the display worked properly but the tester is measruring the battery voltage as 16volts and it goes into a probe loop, so now i will try flashing my tester with other firmwares on this thread and il report back, thanks.
Offline tom666
  • Country: sk
« Reply #1254 on: September 19, 2015, 12:26:22 pm »
Original voltage divider for battery voltage measurement is 10k and 3.3k.
By contrast, the tester Fish8840 used divider with values 47K and 47K.
Note:
Please, use the "quotes" wisely.
Offline papabol_24
« Reply #1255 on: September 19, 2015, 12:48:20 pm »
Thanks @tom666 :), found a working firmware for my Fish8840 tester here:
http://www.mikrocontroller.net/svnbrowser/transistortester/Software/trunk/
I dont know why but the 680ohm resistor inline with the MISO pin opened up, Thanks for the guidance guys :-+
Offline tom666
  • Country: sk
« Reply #1256 on: September 19, 2015, 12:53:54 pm »
Edit:
Use this actual firmware for the Fish8840 Tester:
Fish8840_v1.12k_r554.zip
« Last Edit: September 21, 2015, 05:18:01 pm by tom666 »
Offline papabol_24
« Reply #1257 on: September 19, 2015, 01:14:43 pm »
@tom666, the new firmware you provided works  :-+, nice bold like font too, il do further testing after i replace the open 680ohm ressitor and report back thanks a lot.... :)
Offline tom666
  • Country: sk
« Reply #1258 on: September 19, 2015, 01:47:04 pm »
I'm glad :)
Offline indman
  • Country: by
« Reply #1259 on: September 19, 2015, 02:23:28 pm »
Friends, Karl-Heinz Kübbeler added the very useful and significant changes to fresh audits of a firmware!
Changes concerned the accuracy of samplings of capacities to 100pf. One of participants of the forum mikrocontroller.net suggested to add in makefile a line "WITH_SamplingADC = 1" that increases permission in this range to 0,01pf. Measurement needs to be done on TP1-TP3 pins.
One more addition - the author realized correction of indications of "big" capacities in the additional menu! There was a "Cap correction" point. Values can be changed from-2.0% to +8.0%. :)
Offline papabol_24
« Reply #1260 on: September 20, 2015, 08:51:30 am »
Hello, fully tested the newest firmware from tom666 for my fish8840 tester and its realy great  :-+, i have another tester waiting to be picked up in the post, its also fish8840 but with black case, thanks guys...
Offline madires
« Reply #1261 on: September 20, 2015, 03:30:35 pm »
The additional measurement for low capacitance was submitted by PA3FWM. There will be also one for low inductance (based on a resonant circuit with a parallel known C). The problem is that the firmware with both new features and support for a graphic LCD module will exceed the flash size limit of the ATmega328. The classic HD44780 testers should be fine (for some time). Anyway, we're heading to the 644/1284 to allow new features and options. On my todo list is support for touchscreens which requires some additional I/O pins, the 328 doesn't have.
BTW, the low capacitance measurement is very sensible to probe wires and ZIFs/test sockets. Karl-Heinz mentioned that the difference between an opened and closed ZIF is about 0.6pF and that probe wires are a no-go.
« Last Edit: September 20, 2015, 03:37:51 pm by madires »
Offline Electro Fan
« Reply #1262 on: September 20, 2015, 04:54:14 pm »
Sorry for taking the thread off topic for a short detour on the immediate local road but I've been watching this thread for a while as it progresses toward 100 pages....
Any chance that this particular product might be a reasonable contender?
http://www.ebay.com/itm/New-Small-12864-LCD-Transistor-Capacitance-ESR-Meter-Diode-Triode-MOS-LCR-NPN/171815404897?_trksid=p2046732.c100040.m2060&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20140107095009%26meid%3D4bf4a0d9d5fe4256add580abc3381565%26pid%3D100040%26rk%3D1%26rkt%3D4%26sd%3D171815404897
Or is there something similar (already built, not a kit) that might be a better gift for a student to use as a simple component tester?  Just looking for something that gives hands-on experience / feedback / measurements on a variety of components.  Thx
« Last Edit: September 20, 2015, 07:55:50 pm by Electro Fan »
Offline Overtuner
« Reply #1263 on: September 20, 2015, 05:03:32 pm »
644/1284 because of the 20MHz clock? - well done, it improves the felt speed with higher resolution displays on old-school-8bit-mcu's  8)
the bad thing with them ist the restriction to TQFP-44.
to solve this, I'd recommend to "duplicate" the circuitry for the three test pins, one set on ZIF, the other on wires.
most well designed self-made testers have already a ZIF (or other 3pin) socket AND probe wires on 2mm banana jacks.
Offline Messtechniker
« Reply #1264 on: September 20, 2015, 06:27:37 pm »
As far as I can see there are DIL40 644s and 1284s.
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter, UT216C AC/DC Clamp Meter
Offline Electro Fan
« Reply #1265 on: September 21, 2015, 05:37:03 am »
not sure if these were posted previously; if not they might be helpful
Battery Life Improvement Mod:
General Review:
Offline Overtuner
« Reply #1266 on: September 21, 2015, 09:44:59 am »
of course, yes.
but who wants to have such large bricks of plastics?  ;D
if I had a wish for free - a mega256, with 25MHz, integrated USB like the U4 - within a TQFP-64  ::)
Offline papabol_24
« Reply #1268 on: September 21, 2015, 12:44:42 pm »
Hello :( , aftr a month of waitng i got my 2nd tester from the post office, and when bad luck strikes yay  :( another cracked screen  :palm:
another LCD hunting and i hope this time il get the correct dimensions....
Offline neslekkim
  • Country: no
« Reply #1269 on: September 21, 2015, 12:50:09 pm »
Isn't the 12864 LCD fairly standard in size?
Offline papabol_24
« Reply #1270 on: September 21, 2015, 01:30:44 pm »
No @neslekkim, these testers with case (Fish8840) use 12864 lcd,s with dimensions of 46mmx29mm LxW to propperly fit on the viewing window of the case, a ST7565 Driver and a 12 pin flex flat bar solder connection directly soldered on the atmega328 pcb. there are many 12864 lcd modules on ebay and aliexpress but im having trouble finding the right connector and dimension.
Offline neslekkim
  • Country: no
« Reply #1271 on: September 21, 2015, 02:20:04 pm »
Ah, without the frame, I have the earlier types which uses the types with pinheader, but maybe this would be close?
http://www.ebay.com/itm/271760155514
And I would guess that if you send a message to the seller about yours, maybe he would provide you new display?
Do you have link to the two you bought?
Offline papabol_24
« Reply #1272 on: September 21, 2015, 02:40:28 pm »
Offline ralphd
    • Nerd Ralph
« Reply #1273 on: September 21, 2015, 03:48:29 pm »
Have you tried avr-gcc 4.9.2 or 5.0 with LTO?  10-20% code size reductions with LTO are fairly common.
Unthinking respect for authority is the greatest enemy of truth. Einstein
Offline madires
« Reply #1274 on: September 21, 2015, 04:55:13 pm »
Not yet. My current avr-gcc version is 4.8.1. But thanks for the hint!
