Author Topic: Advantest R6551 Multimeter  (Read 4233 times)
Offline radhazTopic starter
« on: September 27, 2015, 11:59:09 pm »
I bought this a while back. It's a 5.5 digit DMM, pretty well made. It had an issue where it would not measure ACV or ACI. Turns out there is a separate board for measuring AC, which this unit did not have.
I found another unit for sale cheap and took a chance on it. It has the AC board, but it has a bad transformer. I swapped in the AC board and now have (inaccurate) AC readings. :-DD
Here are some pics of the beast:
Offline Vgkid
Re: Advantest R6551 Multimeter
« Reply #1 on: September 28, 2015, 03:02:12 am »
That is a rather interesting meter. I do find it funny to see the 4052 with guard traces.
Gotta love the high impedance daughterboards, and the mix of smd and through hole components.
« Reply #2 on: September 28, 2015, 03:15:59 am »
Any ideas on a poor man's AC calibrator? I just want to get AC kinda sorta close to reality.
Offline Vgkid
« Reply #3 on: September 28, 2015, 03:28:21 am »
Offline lowimpedance
  • Watts in an ohm?
« Reply #4 on: September 28, 2015, 05:43:53 am »
Is changing the transformers over complicated?, or the cheaper unit too beat up?. Just a thought that the one with the dud transformer may actually be okay for cal. with all its 'cards'.
« Reply #5 on: September 28, 2015, 06:19:15 am »
I may try moving the trans over to the duff unit. I do have soldering gear for that.
« Last Edit: September 28, 2015, 06:23:31 am by radhaz »
