I tried making a preamplifier stage and antenna to see if I can receive WWVB. If I can't see it on my scope, there's no point in trying to demodulate it. I made a loopstick antenna using a ferrite rod, 30 AWG magnet wire, and a silver mica 4700 pF cap. The preamplifier is almost a clone of the John Magliacane design from QEX: an instrumentation amplifier followed by an active bandpass filter. He uses a AD620 in-amp, and I chose the INA849 since it's newer and has an edge on noise specs. I also added a buffer op-amp at the end so it can drive a 50 ohm load (my spectrum analyzer).
The antenna and receiver performance check out independently, but I haven't been able to see the signal. I'm either seeing amplified noise in the envelope of the bandpass filter, or a spurious carrier at just under 60 kHz - is that a sign of some interfering switcher nearby? I've tried testing at two locations at different times of day and night, but both are in buildings with neighbors. The pandemic makes it a little hard to call up a friend and ask to come over with gear. Anything else I should try before giving up and putting this on the shelf for a bit?
Some screenshots of the preamp performance to follow...
