tautech, thanks for your suggestions. I will check the FAQ out. You have a lot of energy for answering in the forum. I know you are a distributor in NZ but still, you seem to work hard and it is very much appreciated. The SSA3021X appears to be a beast. I dont really know what I am doing at the moment but I really like the unit so far.
Trev
Thanks Trev my energies are juggled between Dist, hobbies, other business commitments, family and EEVblog.
I too don't have much experience with analysers but I know there's a lot you can find online and in the forum here.
I'll do some checks with my SSA to see if Phase measurement is possible....member hendorog gave me a tiny SMA directional coupler and along with a WiFi SMA antenna it shouldn't be hard to cobble something together to get some SWL info and maybe phase info.
Why ? Because I'm learning too and the some/little knowledge gained helps me support customers better and you guys too.
As Arnie says; I'll be back, hopefully with something that's useful.
Give me a bit, it's lunchtime here and I have to hunt all the bits out.
