Thought I would put these photos up for a bit of fun.
I am about to have a go at EME, 160W out, 1296MHz, Semi PORTABLE!!! (the only place I can use it is in my driveway; bugger)
Home brew LINEAR 30V 15A PSU. Arduino for OV protection and display
W6PQL power Amp, with MiniKits (VK5EME) sequencer , again Arduino for display (hell I can program those little buggers so why change)
Icom 910 with OCXO.
G4DDK Pre-Amp, 0.27dB NF 37dB gain.
WE4MA super feedhorn, used 7" stainless steel flue pipe, ~20dB return loss, 10dB isolation between ports, so both Tx and Rx relays.
4m f/d 0.38, el cheapo satellite dish.
Moves welded to an engine stand (with extension tubes) to widen base, actuators to move Azimuth ~100 degrees and elevation 0-90 degrees.
Am about to start sun noise testing to fine tune position of feed horn.
My wife, daughters and friends think I am a bit crazy, well maybe……..but no beard yet.
