I'm integrating an IC modem on en embedded product and I have some TIS issue. As I have few knowledge in RF (outside tuning an antenna with a VNA) do you know if I can use a CMU or CMW500 (for example as I never seen one kind of device in my life) to inject a LTE signal into the modem and be able to check the noise of the RF signal ?
