Yes.
The picture you posted is commonly known as Reisert winding, designed to keep the input and output separated in order to minimise capacitance.
I use 12 windings of RG-58 (6 turns one side, 6 turns on the other) on a FT240-31 but #43 mix should be ok as well.
