currently im running a arduino pro mini 5v 16mhz + nrf24l01 + pa + antenna as transmitter
and arduino pro mini + nrf24l01 pcb antenna one as reciver also have a oled on the rx
code:
rx
/* Test code for the Radio control transmitter
* Install the NRF24 library to your IDE
* Upload this code to the Arduino UNO
* Connect a NRF24 module to it:
Module // Arduino UNO
GND -> GND
Vcc -> 3.3V
CE -> D9
CSN -> D10
CLK -> D13
MOSI -> D11
MISO -> D12
This code should print the received values to the serial monitor
Please, like share and subscribe : [url]https://www.youtube.com/c/ELECTRONOOBS[/url]
#include <Adafruit_SSD1306.h>
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
const uint64_t pipeIn = 0xE8E8F0F0E1LL; //Remember that this code is the same as in the transmitter
RF24 radio(9, 10);
//We could use up to 32 channels
struct MyData {
byte throttle; //We define each byte of data input, in this case just 6 channels
byte yaw;
byte pitch;
byte roll;
byte AUX1;
byte AUX2;
MyData data;
int packetCounts[10];
int packetCountIndex = 0;
int packetCountTotal = 0;
void resetData()
//We define the inicial value of each data input
//3 potenciometers will be in the middle position so 127 is the middle from 254
data.throttle = 0;
data.yaw = 127;
data.pitch = 127;
data.roll = 127;
data.AUX1 = 0;
data.AUX2 = 0;
void setup()
Serial.begin(9600); //Set the speed to 9600 bauds if you want.
//You should always have the same speed selected in the serial monitor
resetData();
radio.begin();
radio.setAutoAck(false);
radio.setDataRate(RF24_250KBPS);
radio.openReadingPipe(1,pipeIn);
//we start the radio comunication
radio.startListening();
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
memset(&data, 0, sizeof(MyData));
memset( packetCounts, 0, sizeof(packetCounts) );
unsigned long packetsRead = 0;
unsigned long lastScreenUpdate = 0;
unsigned long lastAvgUpdate = 0;
unsigned long lastRecvTime = 0;
unsigned long drops = 0;
void recvData()
while ( radio.available() ) {
radio.read(&data, sizeof(MyData));
lastRecvTime = millis(); //here we receive the data
void loop()
recvData();
unsigned long now = millis();
//Here we check if we've lost signal, if we did we reset the values
if ( now - lastRecvTime > 1000 ) {
// Signal lost?
resetData();
if ( now - lastScreenUpdate < 100 )
return;
// moving average over 1 second
packetCountTotal -= packetCounts[packetCountIndex];
packetCounts[packetCountIndex] = packetsRead;
packetCountTotal += packetsRead;
packetCountIndex = (packetCountIndex + 1) % 10;
packetsRead = 0;
Serial.print("Throttle: "); Serial.print(data.throttle); Serial.print(" ");
Serial.print("Yaw: "); Serial.print(data.yaw); Serial.print(" ");
Serial.print("Pitch: "); Serial.print(data.pitch); Serial.print(" ");
Serial.print("Roll: "); Serial.print(data.roll); Serial.print(" ");
Serial.print("Aux1: "); Serial.print(data.AUX1); Serial.print(" ");
Serial.print("Aux2: "); Serial.print(data.AUX2); Serial.print("\n");
display.clearDisplay();
display.setTextColor(WHITE);
display.setTextSize(0.5);
display.setCursor(0, 0);
display.println("A0");
display.setCursor(20, 0);
display.println(data.throttle);
display.setCursor(45, 0);
display.println("A1");
display.setCursor(65, 0);
display.println(data.yaw);
display.setCursor(0, 10);
display.println("A2");
display.setCursor(20, 10);
display.println(data.pitch);
display.setCursor(45, 10);
display.println("A3");
display.setCursor(60, 10);
display.println(data.roll);
display.setCursor(0,20);
display.println("PPS");
display.setCursor(30, 20);
display.println(packetCountTotal);
display.setCursor(40,20);
display.println("AUX2");
display.setCursor(70, 20);
display.println(data.AUX2);
display.display();
note the base code is from electronoobs and the pps part which i tried is from iforce2d but it doesnt work
![Sad :(](https://www.eevblog.com/forum/Smileys/default/sad.gif)
(HELP HERE)
TX
/*A ba
sic 4 channel transmitter using the nRF24L01 module.*/
/* Like, share and subscribe, ELECTRONOOBS */
/* http://www.youtube/c/electronoobs */
/* First we include the libraries. Download it from
my webpage if you donw have the NRF24 library */
#include <SPI.h>
#include <RF24.h>
/*Create a unique pipe out. The receiver has to
wear the same unique code*/
const uint64_t pipeOut = 0xE8E8F0F0E1LL; //IMPORTANT: The same as in the receiver
const int ledPin = 2;
int ledState = HIGH;
int blinkcount = 0;
unsigned long previousMillis = 0;
const long interval = 100; //blink interval
const long interval2 = 1000; // pause interval
unsigned long currentMillis ;
unsigned long previousMillis2 = 0;
RF24 radio(9, 10); // select CSN pin
// The sizeof this struct should not exceed 32 bytes
// This gives us up to 32 8 bits channals
struct MyData {
byte throttle;
byte yaw;
byte pitch;
byte roll;
byte AUX1;
byte AUX2;
MyData data;
void resetData()
//This are the start values of each channal
// Throttle is 0 in order to stop the motors
//127 is the middle value of the 10ADC.
data.throttle = 0;
data.yaw = 127;
data.pitch = 127;
data.roll = 127;
data.AUX1 = 0;
data.AUX2 = 0;
void blinkSteps0to2() {
// save the last time you blinked the LED
previousMillis = currentMillis;
// if the LED is off turn it on and vice-versa:
if (ledState == HIGH) {
ledState = LOW;
blinkcount++;
} else {
ledState = HIGH;
blinkcount++;
// set the LED with the ledState of the variable:
digitalWrite(ledPin, ledState);
void blinkStep3(){
unsigned long currentMillis2 = millis();
ledState = HIGH;
if (currentMillis2 - previousMillis2 >= interval2) {
previousMillis2 = currentMillis2;
blinkcount = 0;
void setup()
//Start everything up
Serial.begin(9600);
radio.begin();
pinMode(ledPin, OUTPUT);
radio.openWritingPipe(pipeOut);
resetData();
// Returns a corrected value for a joystick position that takes into account
// the values of the outer extents and the middle of the joystick range.
int mapJoystickValues(int val, int lower, int middle, int upper, bool reverse)
val = constrain(val, lower, upper);
if ( val < middle )
val = map(val, lower, middle, 0, 128);
else
val = map(val, middle, upper, 128, 255);
return ( reverse ? 255 - val : val );
void loop()
// The calibration numbers used here should be measured
// for your joysticks till they send the correct values.
data.throttle = mapJoystickValues( analogRead(A0), 13, 524, 1015, true );
data.yaw = mapJoystickValues( analogRead(A1), 1, 505, 1020, true );
data.pitch = mapJoystickValues( analogRead(A2), 12, 544, 1021, true );
data.roll = mapJoystickValues( analogRead(A3), 34, 522, 1020, true );
data.AUX1 = digitalRead(4); //The 2 toggle switches
data.AUX2 = digitalRead(5);
radio.write(&data, sizeof(MyData));
currentMillis = millis();
if (currentMillis - previousMillis >= interval) {
if (blinkcount <= 3) blinkSteps0to2() ;
else blinkStep3() ;
The above code is based of the code of electronoobs and the blink without delays sketch parts was included and the led blinks with out messing the transmitter stuff
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
i need help to get pps readings on the reiever to test weather it is sufficient for controlling a quadcopter its intention
and also to send 3 - 4 voltage readings form RX > TX ( 3s - 4s lipo is planned to be used)
anyone who has do this kinda stuff before please help
