FTG.
The Swedish transponders operate on different freqs then local.
I have received my ordered 22-dB ant preamp with GTE/4G filter and it mounted 6 cm from the rear end of my existing antenna and it boosted reception of a single Skåne Chan4 HD to allow reception some days very clearly for most hours, yet for some hours on some days the receiver shows no signal.
The receiver's built in Advance System Info shows signal strength and quality and the signal strength is 100% and the quality varies second by second from in 3% steps 0 to 23%, yet 90% of the time signal strength is greater than 2% Yet there is no signal at all from SV1 SV1-HD, SV2, SV2-HD, SV24 Cultural channel.
I last allowed a channel scan some two-weeks ago and I'm now wondering if these channels, which are in the list of active channels, is still valid.
Catch 22: If I allow another scan, the receiver could possibly delete the channels I want from the active list, that means I cannot set the receiver at all to show a channel not registered by a scan, so I cannot set the receiver to a channel of interest and cannot see any signal strength graph to try to find the best position to point the antenna and I have no signal to work with.
The odd thing is the TV4 HD Scåne transponder is much further away then the Målmo transponder!
