Let me try putting down some number, I'll use metric since that's what I'm familiar with and since wavelength is in meters
Let's start by calculating Lambda for 250 Mhz, we have 300/250=1.2 meters, that's our wavelength, now, since our transmission line isn't perfect we should take in account the coax velocity factor, let's assume it's 0.66, in such a case 1.2*0.66=0.792 or 79.2 centimeters, this is our "corrected Lambda", now, starting with such a value we can calculate 1/4 wave as 79.2/4=19.8 centimeters; now that we have 1/4 Lambda (with correction) we can calculate our coax length, willing to start with 1/2 wave we just do 19.8*2=39.6 centimeters and then, willing to add 1/4 wave we'll have 59.4 centimeters, at this point we convert 39.6 and 59.4 from centimeters to feet obtaining 1.299 ft and 1.948 ft which will be the lengths we'll use for our coax cables
HTH
