Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
RF, Microwave, Ham Radio
Transmit many LVDS clock signals across multiple boards.
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Transmit many LVDS clock signals across multiple boards. (Read 1679 times)
msngupta
Contributor
Country:
on:
June 03, 2016, 03:25:17 pm »
I am designing a system where I need to many transmit LVDS (say C+ and C-) clock signals (around 1GHz) across different boards. The solution I see in many reference circuits is to use 2 SMA coaxial cables (one for each differential signal). I find this rather costly and clumsy (4 SMA connectors and 2 cables for one signal). How can I transmit the LVDS signal using one cable?
I was thinking of 2 ways to resolve this
1) Converting the differential signal using balun transformers (on both receiver and transmitter ends). Convert differential to single ended and then back to differential.
2) One more solution I was thinking (not sure whether this is correct) is to connect C+ to core and C- to the shield of the coaxial cable. Can this be done ?
Can someone suggest which solution should I go for? Or any other better cost effective solution where I can properly transmit the signal using a single cable?
Thanks,
Sainath.
Logged
tggzzz
Super Contributor
Country:
Numbers, not adjectives
Re: Transmit many LVDS clock signals across multiple boards.
Reply #1 on:
June 03, 2016, 03:44:15 pm »
Google for controlled impedance connectors and, if necessary, microstrip/stripline/coplanar waveguide.
Differential signalling better than single-ended from the point of view of noise immunity and EMI/EMC.
Logged
Glider pilot's aphorism: "there is no substitute for span". Retort: "There is a substitute: skill+imagination. But you can
buy
span".
Having fun
doing more, with less
dmills
Super Contributor
Country:
Reply #2 on:
June 03, 2016, 05:28:38 pm »
I dont know about 1GHz, but sata cables and connectors are one of my favorite things for LVDS between boards.
If you want something much less pony, Samtec have what you need for up to way more then 1Ghz.
Regards, Dan.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
