Author Topic: Just got a ham license upgrade, now what?  (Read 3091 times)
Offline technixTopic starter
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« on: August 10, 2022, 04:52:47 am »
I just got my license upgrade this Sunday, getting my HF permissions on my US license. Now what? I can't quite afford the equipment yet.
73 de KC1PQO
Offline KE5FX
    • KE5FX.COM
Re: Just got a ham license upgrade, now what?
« Reply #1 on: August 10, 2022, 06:26:14 am »
Build something!   :-/O
(Although don't spend the big bucks for a new handbook; used old ones are fine.)
Offline Wallace Gasiewicz
« Reply #2 on: August 10, 2022, 10:47:10 pm »
Go to a hamfest and see if anyone is selling an old radio cheap.
Offline rgrEngage
« Reply #3 on: August 11, 2022, 01:30:13 am »
Check out http://www.remotehams.com
Join a club and meet some operators, many are willing to show off their stations and give you a chance to operate.
Offline El Rubio
« Reply #4 on: August 11, 2022, 02:08:04 am »
Is there a ham radio club in your area? Lots of clubs have a club station and some Elmer should be willing to show you the ropes on it.
I have bought & sold many ham radio related items on
 https://swap.qth.com/index.php
I saw someone has an Icom IC-718 for $160. He said it doesn’t transmit. That’s a current rig that you can get parts for if you’re into repairing it. There are others, but you have to sift through a bit. Almost all sellers are hams and I have never been burned by anyone on that site.
Make a basic resonant dipole or OFCD for multiband ops.
Soundcard digital modes like PSK31 are easy to get up and running as long as you have a soundcard. 20 Meters -14.070 was very popular.
Offline vk3yedotcom
    • vk3ye dot com (radio articles and projects)
« Reply #5 on: August 12, 2022, 12:04:46 pm »
Possibly the cheapest way is to build a very simple Morse transmitter (say 2 or 3 transistor) and use a web SDR as a receiver.
That will enable you to hear yourself, provided it's the right distance away and you have an efficient antenna.
If your crystal frequency is in a useful part of the band (7 MHz crystals are widely available) you could even call CQ and make contacts, hearing people via the web SDR.
There will be a small delay but it's still workable.
A very simple transmitter (though a bit more power would be desirable)
NEW! Ham Radio Get Started: Your success in amateur radio. One of 8 ebooks available on amateur radio topics. Details at  https://books.vk3ye.com
The following users thanked this post: bd139, duckduck, DH7DN
Offline mag_therm
« Reply #6 on: August 13, 2022, 05:55:45 pm »
I recently obtained my call in USA after initial VK call then long time with no activity.
I am focusing on  only digital 30, 20 and maybe 17 m .
Plan so far:
Completed items:
Set up 2 dedicated  Linux computers with 13.8 V supply.
Restore, update swl receiver with added dds.
Swl antenna 40 to 17 m
Purchase vintage Spect An.
Purchase new 'scope to assist the vintage ones.
Add ground rods and weather proof  antenna cable access to basement .
In progress:
Hermes single board dual txcv
(Late delivery by chip shortages)
Build 13.8 V UPS , about 50 A.h battery cap.
Build lightning arrestor panel for antenna cables.( Had strike damage already)
Future, not fully planned yet:
30, 20 m ocf dipoles
HF linear amp about 50 to 100 Watt. 13.8 V  I think I will just purchase one initially although prefer building stuff rather than buying appliances.
Offline duckduck
  • 20Hz < fun < 20kHz, and RF is Really Fun
« Reply #7 on: September 01, 2022, 05:14:30 pm »
73 de KC1PQO
Got my Technician license (HF limited to 10 meters, CW only) a few weeks ago. Studying for my General license (TX on almost all HF) now. Low-power radio kits are much cheaper than a new IC-7300 and are a good excuse to solder:
https://www.hamradiosecrets.com/ham-radio-kits.html
« Last Edit: September 01, 2022, 05:18:27 pm by duckduck »
Offline A.Z.
« Reply #8 on: September 02, 2022, 05:20:05 pm »
73 de KC1PQO
http://www.4sqrp.com/kitIndex.php
Offline mag_therm
« Reply #9 on: September 02, 2022, 06:00:18 pm »
There is a new book just published. My copy arrived 3 days ago and I have started on its 400 pages.
A.Peter AC8GY and Dr J Purdum W8TEE "Theory and Construction of the T41-EP Amateur Radio SDT" EP means experimenter's platform
https://ema.arrl.org/2022/08/30/w8tee-ac8gy-building-an-hf-cw-ssb-20w-software-defined-transceiver-at-sci-tech-ars-hybrid-meeting-august-30-2022/
Arduino IDE, all on Teensy 4.1,  DSP is not done on external computer.
This is open source project is a transceiver kit and they are working on sources of "semi kit" parts.
The book covers the pcbs and firmware and goes into descriptions of all the DSP functions, although they cite references for the in depth theory of the underlying libs.
One is Richard Lyons "Understanding Digital Processing" 3rd Edition.
  • Country: cn
    • My Untitled Blog
« Reply #10 on: October 21, 2022, 04:20:48 am »
So far I have acquired a Kenwood TS-2000 all-band transceiver, a DIY manual end fed antenna tuner, a 30m roll of wire and a RigExpert AA-30 antenna analyzer. Maybe that is all I need to hop on HF?
Offline fourfathom
« Reply #11 on: October 21, 2022, 06:16:13 am »
That's more than many of us started out with.  Just do it!  For an end-fed antenna you will probably need a ground connection, but that doesn't have to be fancy.  Use a metal waterpipe, or pound a spike into the damp earth, or lay out a wire on the ground, or clip to a metal downspout, or...  Don't wait for perfection, just get on the air with whatever you can throw together.
-Paul, wb6cxc
We'll search out every place a sick, twisted, solitary misfit might run to! -- I'll start with Radio Shack.
