was there a fault lol,in a word yes,i brought it from ebay as fully working,gave it to a friend to test as at the time i had no hf antennas up,it was only doing 12w max on tx,that was blown pa drivers,when i checked all the memory slots they were all 11m chicken band!,then had bad caps on the car board,low rx sensativity,that was a bad ic on the filter board dad digital transistor on the rf board,pll going out of lock when warm,bad display caps also,its been a lot of work so far,its working fine but,when i renewed the pa board and the other bad parts,i was working thru doing a realignment and cot stuck at the null section as couldnt figure out what it was sayying 100% so stopped there,its been niggling me ever since,it seems fine on air,what would the symptoms be of the null out of whack on air,ie is it worth bothering with?,also would that alter the atu matching range as this seems to match 4-1 swr ratios,thought they were only good to 3-1 max.
