Another thing that needs to be pointed out; keep your signal levels low, your analyzer will see signals levels from outside of the range you are looking at, too much total signal power into your analyzer will damage it unless there is some form of input protection.
If you had a small ham Log Periodic VHF/UHF portable antenna normally used outside, how could you determine it's normal sensitivity and overall performance outside so you could in turn determine how many dB of attenuation would be sufficient in an attenuator so you could select an appropriate attenuator for using the antenna safely inside or outside with an SA? (Only for receiving, not transmitting.) Any guess on how many dB's of attenuation this might turn out to be? What are the typical dB attenuation ranges for simple passive inline attenuators? What Watt rating would be sufficient? The SA is worth more than the antenna - just want to be cautious and conservative on this - better to be on the safe side to protect the SA. Is there such a thing as a fairly wide ranging variable attenuator? One last question, is there any reason to also use a DC Block in line with the attenuator to help further protect the SA?
Thanks
Update: I found and measured a couple items shown below. The first two photos show a Tektronix 011-0099-00; this model is a Terminator and not an Attenuator; it seems to provide about 3 dB of attenuation. The second two photos show a Tektronix 011-0059-02; this model is labeled as a 10X Attenuator and it seems to provide about 20 dB of attenuation. Moral of this story is don't confuse a Terminator for an Attenuator.
I'm guessing the 011-0059-02 10x Attenuator might suffice for what I originally asked about in this post (although interestingly this Attenuator is rated for 2 Watts vs. the 50 Watt rating on the Terminator), but if anyone thinks differently about this please let me know. Thx
PS, I'm guessing that even if I happen to tune a strong local FM broadcast signal on the antenna while watching the signal on the SA the most the SA is going to see is milliWatts so 2 Watts is plenty sufficient, yes? Thx
