I did mostly the same, not with simulation but with a TDR. The first try was my
standard SMA decal found in my Altium lib, probably for the normal 1.6 mm FR-4
with thick center conductors on the sma. JL on sci.elecronics.design (usenet)
wrote he measured IIRC 80-90 Ohms for these SMAs in free air.
ed. not for the barrel but for the part that will end up on the board.
Not much reserve for the local capacitance of the board.
I did a 4 layer board at JLCPCB with 4 tiny LMX2594 synthesizers and had free
space for test structures. I tried 2 of the fat SMAs, interconnected with a 12 mil
line. 11.5 mil on top and GND on the inner layers are 50 Ohm according to the
JLCPCB impedance calculator. And yes, the calculator is exact.
On the TDR it showed that the 12 mil line was not too bad, but the SMAs had
locally much too much capacitance (notch in the impedance/reflected voltage
line). Even the amount of tin played a role.
In V2 of the board, i made the center pad of the SMA much smaller and did
cut outs on the inner layers. The notches were gone, very slightly inductive now,
sorry, I cannot find the screen shot. Consider it slightly overcompensated, but
MUCH better.
But the SMA is now a Rosenberger and not cheap Chinese. The inner conductor
is MUCH thinner. If you find a cheap SMA launcher with a thin inner conductor,
I'm all ears.
I did some fancy corners on the 12 mil line to see if I get punished, but no, in
comparison to the SMAs, that's harmless. Only the first picture is with the fat SMA.
The picture SMA_cutout.png is taken from the V2 synthesizer, not from the test structure.
Apply the lessons learned immediately :-)
On that exerpt of the amplifier output: (SMA_cutout.png)
Red is top, green is bottom, blue is inner layer 1, layer 2 is invisible and unimportant.
I don't think that the taper will play much of a positive role, it will in contrary increase
the capacitive load.
regards, Gerhard
