But can it actually handle the rated power? A while ago there was a thread about cheap Chinese attenuators that didn't meet their power ratings.
Personally I rather buy used brand attenuators from Ebay or new than taking a chance with the cheap Chinese models.
I am not sure what the actual power ability is. Ratings are typically rms, but maybe it's abs for these items. I usually like to stay below 1/2 rating, so I would expect I could use these 1w rms. Obviously some signals are not nice, square, triangle, wavvy sine.
For ~$3usd you buy a few, run up some voltage on them until you get 2w, let it burn-in at 2w for 8hrs, let cool, re-measure vswr and such.
For ~$3usd you buy a few, up the voltage until it frys
For ~$3usd you buy a few, cut them open and see what's inside.
EEVb is home of "rip in, tear down", yes?
They are however the 1st set in my china pile that actually tested to be what the seller said they are, at least in vswr & attenuation. Never did any LCR or watt testing.
