Hello everyone.
First of all I have to say, that I am not very familiar with RF circuits and so, if I say something very stupid, please understand.
But, I will try to explain as more details about my idea, as possible.
I have the following design: MAX2750 VCO coupled with ADL5611 gain block. Frequency range : 2.4 - 2.5 GHz. PCB is made on ROGERS substrate and is etched by hand. This is only hobby project, so is is not worth to order ROGERS or PTFE PCB, since it will be very expensive.
This design works very well. But, I would like to increase the output power. I think, this can be done by connecting more gain blocks in series, for example, ADL5611, followed by SKY65162. ADL5611 has higher gain, but less output power. SKY65162 has lower gain, but higher output power. Parameters of the used parts in specified frequency range can be summarised as following:
- MAX2750. Output Power: -3 dbm.
- ADL5611. GAIN: ~21 db. Output power (OP1): ~ 20 dbm.
- SKY65162. GAIN: ~13 db. Output power (OP1): ~29.5 dbm.
If all this stuff is connected in series, output power, theoretically, will be equal to : -3 + 21 + 13 = 31 dbm. A bit higher, than OP1 of the SKY65162, but not dramatically. Also, real gain and, as a result, output power will be a bit less, because of non-ideal PCB design.
Typically, inputs and outputs of gain blocks are capacitively coupled and recommended capacitor values are specified in datasheets. So, when recommended circuits for both gain blocks are combined in series connection, the following circuit is produced:
So, my main question is about the part of the circuit, where output capacitor of the ADL5611 (100pF) is connected to the input capacitor of the SKY65162 (0.8 pF). Should I keep both capacitors (100 pF + 0.8 pF)? Or should I keep only 0.8 pF, since it is series connection and smaller capacitance is dominant in this case? Or, maybe, some other option?
