Hello everyone,
I spent endless hours searching for an antenna that I could use on my project. I need a Linear UHF RFID with a narrow BeamWidth (less than 10 degrees) and around 4dBi gain that can fit on a device 80mm x 70mm. Do you know if it even exists this type of antenna? I'm quite new in the field so I would really appreciate it if you know someone who sells these types of antennas.
Thanks in Advance.
