Author Topic: Scratch-build AM Superhet  (Read 3266 times)
Offline Daniel BingamonTopic starter
« on: April 26, 2022, 01:41:47 am »
My latest scratch build project is to build a simple AM superhet receiver on top of an older radio chassis in which someone removed the old circuit.
It has a gang of 0-470 pF Variable capacitors  - I'm using two of them.
This is the schematic of what I have in mind.   I appreciate any comments on anything that stands out as an outright problem.
I've not use the SA602A - which is like the NE602.   So this is a self-learning moment.
Don't worry about the coil values.
The following users thanked this post: caulktel
Online Circlotron
Re: Scratch-build AM Superhet
« Reply #1 on: April 26, 2022, 01:58:10 am »
MOSFET gate looks vulnerable to static.
« Reply #2 on: April 28, 2022, 12:28:01 am »
Protecting the MPF102 gate.   Zener's back to back a start?
Also, I realized I had a ground missing on the LO circuit.
I've numbered the components for reference.  Note:  X1 is a ceramic resonator.
Here is new drawing:
Online A.Z.
« Reply #3 on: May 01, 2022, 08:08:13 am »
change the input stage to a common gate,  that will give you a better match for low impedance antennas, move the diodes between the antenna and the input capacitor, not after it, optionally consider adding a low pass filter between the antenna and the JFET stage
see here for some ideas
https://www.eevblog.com/forum/rf-microwave/common-gate-wideband-rf-amplifiers/
and here's another approach which offers both a preamplifier and a preselector stage
http://www.arrl.org/files/file/QEX_Next_Issue/Jan-Feb2018/Steber.pdf
you may even combine the two ideas, placing a low/unity gain common gate wideband stage at the antenna input and following it with a tuned preamp offering adjustable gain
« Last Edit: May 01, 2022, 08:42:39 am by A.Z. »
Offline CJay
« Reply #4 on: May 01, 2022, 12:51:25 pm »
Change the zeners to a pair of 1N4148 connected inverse parallel, use an antenna coupling transformer something like the KANK3334R (Toko no longer manufacture them but there are NOS and modern equivalents available)
Take a look around the web, something like the GQRP Sudden RX project kit will give you ideas, ARRL handbook is useful but if all you want is BCB AM then a lot of the ham projects just add layers of complexity which aren't useful for your needs right now but may be useful later if you decide to 'do more'
Ignore part numbers (schematic fragment borrowed from a CB Radio schematic)
The following users thanked this post: Daniel Bingamon
« Reply #5 on: May 01, 2022, 01:44:19 pm »
Common gate, hmm.  I would have never thought of that.
« Reply #6 on: May 01, 2022, 01:45:28 pm »
1N4148, ok - that's good.  Thanks.
Online A.Z.
« Reply #7 on: May 01, 2022, 05:32:31 pm »
are you kidding or what ?
anyhow, have a look at those designs
« Reply #8 on: May 01, 2022, 06:55:11 pm »
Seriously, I haven't done much with common gate before.
This is more of my hobby.  My day job is programming.
Online A.Z.
« Reply #9 on: May 02, 2022, 08:46:16 am »
I see, ok.
As for the protection diodes, see the notes here http://www.kk5jy.net/rf-clipper/
As for the common gate stage, it's a quite flexible circuit, especially if used as a "buffer" to match a low impedance antenna to the high impedance input of a receiver, I recommend you to check the two papers (links) I posted, since they may give you some ideas about designing your receiver input stage; as I wrote, an idea may be using a very low gain common gate stage right at the antenna input and then follow it with a tuned preamp offering adjustable gain and, from there, to the receiver stages; such an approach will allow you to have a "preselector" stage which will improve your receiver performance at the cost of a slightly additional complexity
Another approach to the input stage may be using an AD605 IC, either used with a varactor tuned stage (preselector) or as a wideband preamp, if you look at the datasheet
https://www.analog.com/media/en/technical-documentation/data-sheets/ad605.pdf
you'll see that the AD605 offers a -14dB to +24dB range, by adding a -10dB attenuator you'll be able change such a range to a -24dB to +24dB one, the gain/attenuation may either be controlled manually (a potentiometer) or you may control it using an AGC circuit or use a mixed setup offering both AGC and manual setting (to adjust the max gain)
« Reply #10 on: May 02, 2022, 11:09:47 am »
I'll have to make a filter for local stations.  One of which is WLW 50kW only 3 miles away by air.
Online A.Z.
« Reply #11 on: May 02, 2022, 02:06:09 pm »
instead of a filter, you may have a decent preselector at the antenna input; please, reread the thread (and the various links)
« Last Edit: May 02, 2022, 03:02:08 pm by A.Z. »
« Reply #12 on: May 07, 2022, 09:35:41 pm »
Online Circlotron
« Reply #13 on: May 08, 2022, 11:53:34 am »
C12 and D3 in series is an issue.
The capacitor will charge to a certain DC voltage and then that detector circuit will stop working.
Also for the audio amplifier there needs to be a capacitor of say 1000uF between the LM386 and the speaker and a small capacitor between the volume pot wiper and the amplifier input.
« Last Edit: May 08, 2022, 11:57:55 am by Circlotron »
Online A.Z.
« Reply #14 on: May 08, 2022, 04:09:05 pm »
right, and there are some other spots which will probably need to be reviewed; as is, the circuit seems a straight copy/paste of several different circuits w/o adapting each other; good for brainstorming, but a minefield if one will try it as is
« Reply #15 on: May 08, 2022, 10:30:56 pm »
Yes, some copy/pasting.  I've also guesstimated some of the values.
The LM386 is pretty basic, I've made those before.  The 2N5308 is out of a Heathkit SW-717.  I do want to put a capacitor in front of the LM386 somewhere to get rid of the RF.
Maybe a resistor after C12 to keep any charge bled off.
Offline Jeff eelcr
« Reply #16 on: May 27, 2022, 02:14:40 am »
Two C12s?
Jeff
Offline vk6zgo
« Reply #17 on: May 27, 2022, 03:57:25 am »
Shift the first LC tuned circuit to the antenna side of the MPF102, otherwise your FET is wide open to powerful signals of any frequency, which will mix & give you unwanted products within your tuning range.
Try to look at some old tube type receiver designs, they did things for good reasons.
I used to work at a combined AM Broadcast & HF radio Comms station, in the lunchroom of the separate Comms building, we had an old domestic mantel radio.
It could receive other AM stations, while being, maybe 300metres away from the "Dual Mast" which was radiating 55kW from one station, & 10kW from another.
PS: You will get mixing products from D4 & D5, too!
« Last Edit: May 27, 2022, 03:59:50 am by vk6zgo »
« Reply #18 on: May 27, 2022, 11:09:37 am »
"PS: You will get mixing products from D4 & D5, too!"
So, voltages on the line could cause the diodes to act like capacitors?
I saw a radio on youtube that used ordinary diodes to tune with.
This mixer circuit is out of my comfort zone, I may try something more basic.
Online Circlotron
« Reply #19 on: May 27, 2022, 12:08:21 pm »
The diodes will act like a mixer.
https://en.wikipedia.org/wiki/Frequency_mixer#Diode
