I'm in the process of replacing the notorious 1GC1-4210 prescaler (custom HP/A/K part) that has bricked countless ESG* signal generators and ESA44* spectrum analyzers such as the E4402B. Quick summary for those not familiar : the 1GC1-4210 divides the YIG signal (3-7GHz) by 1,2,4,8, or 16 inside a PLL loop, depending on 3 mode-select pins. On the spectrum analyzers, only the ratios 8 and 16 are used :
One viable repair strategy is a small (tiny !) pcb with two chained HMC862A dividers (1,2,4,8 ratios). I thought this was a bit wasteful (the HMC862A is quite expensive) since only 2 ratios are needed, so after a bit of research I'm hoping one HMC862A wired to divide by 4 or 8, followed by an ECL divide-by-2 (MC100EP32), might work :
However I have doubts on the compatibility of the input/output structures (see datasheet extracts below) : the HMC862 has apparently a 50ohm output, probably similar to the original 1GC1-4210, and meant to be AC-coupled to the next stage; I'm not sure how well it would play if connected directly to the ECL divider ?
And (possibly more problematic), this ECL divider would end up driving the original AC-coupled attenuator, and I think this would probably require a 50R on both outputs ?
Really hoping I don't need ac-coupling and termination between the HMC and ECL divider, as this pcb is extremely tiny and needing 5-6 extra passives would make this solution much less attractive. I've attached a tentative layout to give an idea of scale - 9.2x6.3mm really doesn't leave much space at all :
