Unfortunately MRF300 comes in a thermally sucky package, don't try to dissipate more than 50W in it. For linear operation that means you are limited to about 50W of output per transistor (you will need to reduce supply voltage). My transistor of choice is always the MRFE6S9125N, it costs around $3 refurbished but it's difficult to obtain outside china. You need to solder it (and the pcb) to a copper plate, and mount the copper plate on a big heatsink with fan.
I guarantee that the MRF300 package (TO-247-3) can handle many hundreds of watts and is not limiting performance. I've built many amplifiers with MRF300 and tested MRF300 in all conditions (including 200W+ watts thermal dissipation in long cycles) under thermal imaging, the package is good enough for the job as long as common sense thermal interfacing rules are applied (flat surfaces, even pressure, good quality TIM etc). The only challenge is the fact that there is only one bolt that holds it down and overtightening warps aluminium / copper; this is solved by either using a press-down clamp over the whole package with additional bolts, or (my recommended solution) by using liquid metal as a TIM; this offers lowest thermal and electrical resistance and the mounting pressure is not critical, but needs a copper heat spreader.
Also, there are other devices in the TO-247-3 package designed for much higher power dissipation, with much lower Rth-j; see IXYS IXFK80N60 / IXFX80N60 for example.
Thats doable, would that mean I could get 450W or so from two? That seems like a lot of power from two small devices, presumably they need to be very well provided with heat sinking?
Yes- looks good!
He has an article on qrp blog but I cry foul, this isnt QRP at all..
This looks very nice.
That's my kit, I'm also offering a Low Pass Filter board as well as a Backpanel Unit with some accessories. A color touchscreen Control Unit is coming this month as well. If you have any questions, ask away.
/shameless plug
Going back to the main subject, if you just want to get on the air it's not economical in the long run to build stuff. It looks cheap now, buy you'll soon realize you want more features, QRP is frustrating as hell in this deep solar minimum we're going through, you will need some test equipment, you will break some stuff, you will make some bad choices and whatver you build won't have much market value if you want to upgrade later. Keeping an eye on eBay for a while, you'll be able to find a used Yaesu FT-747 / Kenwood TS-130S / Icom IC-730 for US$200, you'll get a solid 100W output radio with a good set of features for a beginner and it will keep its market value very well if you want to upgrade later.
However.
I started Amateur Radio by building my equipment (early days of SDR). It was a very long process that included a lot of reading and learning, testing and rebuilding, frustration and rewards. If you're looking to learn, understand what you're doing and enjoy this hobby to the fullest, definitely go this way, it will open up an entire world for you. This is what Amateur Radio is all about really, experimenting with radios stuff.
