I am trying to piece together a simple programmable 30 MHz to 1300 MHz single-channel narrow-band FM receiver design using a ADL5387 and ADF4350 synthesizer. I presume a zero-IF or near zero-IF design would be the best choice. I have looked at the simple IQ analog demodulators used in the uSDX Transceiver and the SuperH receiver, but neither seems a perfect fit for a stand alone receiver. Each receiver would be programmed for a specific frequency and would use a custom made pre-selector front-end. The output would typically be flat analog audio at 600 ohm line level of 0 dBm, but a option for de-emphasis would be nice. The stand-alone receiver would be an open source hardware and software project. I have looked at other designs using a high-performance stereo DACs like the MAX9860 and a STM32 processor, but cannot locate the necessary software to bring it all together. Any thoughts?
