I measured a 20dB attenuator with a NanoVNA. The attenuator was connected only to VNA and had nothing on the other end. I think the return loss should have been 2*10dB, but it was only about 24dB. I used a low frequency, less than 5MHz.
it's incorrect to measure VSWR/RL for attenuator with no load on the output. Because when output is not loaded it leads to impedance mismatch and as result VSWR will be high. You're needs to put 50Ω terminator on attenuator output for proper measurement.
it's incorrect to measure VSWR/RL for attenuator with no load on the output. .
Quote from: radiolistener on January 17, 2024, 08:01:15 amit's incorrect to measure VSWR/RL for attenuator with no load on the output. .Unless that is what you want to know.
Quote from: ejeffrey on January 17, 2024, 04:09:27 pmQuote from: radiolistener on January 17, 2024, 08:01:15 amit's incorrect to measure VSWR/RL for attenuator with no load on the output. .Unless that is what you want to know.What would be a practical use of that figure (RL for unloaded att) ?
