This is a Racal TUAAM automatic antenna tuning unit or ATU. Nice bit of kit but basically the function is to automatically match an antenna to the radio set and feed without any technical knowledge. This was usually bolted to the front of a Land Rover in a box and deployed as part of the Clansman radio system. It covers HF bands only from what I can find out about it. On a quick observation, so don't quote me on this, it does it's thing through RF sampling and a fully analogue control loop that controls the variable capacitors driven via motors. I suspect this uses a crude servo system looking at the system layout. There is no microprocessor or intelligence in this at all, it's all electromechanical and analogue glory! Examining everything, the last date code is 1991 so not that old either.
Bought this to nick the air variable capacitors from. Turns out to be a goldmine of nice parts. Total cost £16.50.
Comes in a large sealed milspec aluminium case as expected. This is promised to the wife as a plant pot. The outside is boring so I've omitted it.
Inside views:
![](http://i.imgur.com/sirsrZ4.jpg)
![](http://i.imgur.com/k0Nqvyw.jpg)
![](http://i.imgur.com/OA6896Y.jpg)
![](http://i.imgur.com/JPSHBDV.jpg)
And the boards...
![](http://i.imgur.com/EYXRTqC.jpg)
![](http://i.imgur.com/OKxigjw.jpg)
There are three motor driver boards. On the basis that there are 4x BFY52s, they look like H-bridge configuration with a canned 741 op amp. There are two misc control boards, one containing a dual opamp, a single opamp and a ton of diodes and I assume this is the brains of the device. There is a tiny switch mode identified by a big transistor, a canned 723 regulator, power transistor which is pretty cool as it's powered via a 12v source and based on the symmetry of the board it looks like it generates two voltage rails for the opamps. The side of the unit has the RF section which I haven't dismantled yet. Maybe tonight but I've got to get the kids from school now...
