Hello everyone!!
I am Looking for help to build a :
replicable,
DIY,
small sized,
infrared deep tissue heater
it’s size should be a rectangle 4,5cm (width) x 15cm (length) x 1,5cm (or 2cm) (thickness)
With a wired control device
and above each “resistance”(heater vertical (parallel to the width) band) a button to shut it off individually
the deep heat should reach 38,9C (102F) and 43,3C (110F)
and reaches them in 2minutes max (or maybe add an Intensity button/roller)
thx for reading!!!!
