Thank you everybody.
I am particularly interested in understanding this properly:
an atu (be it a pi, l,t ... match) will have losses, a good antenna with a proper impedance transformer (and proper grounding/choking) will have lower losses
what is the reason? Can you point to some general argument/calculations that would help me reach the same conclusion regarding T-match VS transformer? I haven't been able to find much.
In your case the antenna (wire) is directly connected to the tuner, so either a transformer or a matching unit will make little difference from the loss/efficiency standpoint; the only problem (let me call it so) is that with that config you will have "RF in the shack" since part of the ratiating element (the antenna) is inside; that's why it's usually better to either use a remote antenna matching unit sitting at the (external) antenna feedpoint or a transformer (again, at the feedpoint) and feeding the antenna using some coax (with proper choking/grounding).
As for simulating the antenna, you may have a look at the free 4NEC2 program which you can download
here it will allow you to create a model of your antenna and then perform a number of simulations; for a primer on 4NEC2, see
this and
this (you can find more guides/manuals/primers on the net)
in your case, you have two main issues, first of all your 7 meters antenna is too short for the 20 meters band (14MHz), second, you lack a counterpoise, the latter may even be a piece of wire hanging down from the window and connected to the gnd of your matching unit (or transformer); as I already wrote, my suggestion is to start by going
here and selecting from the GREEN numbers list the longest length of wire which will fit your available space, next build a 9:1 UnUn like
this one (the toroid may be smaller given that you'll use low power); done so, pick up some length of coax to connect it between the UnUn and the wire and connect a second run of wire hanging down from the UnUn "gnd" connector; use a piece of rope to hold the UnUn and the wires as far from the building as possible and a second one to hold it at the far end; that will give you a pretty decent antenna, sure it won't be a Yagi or whatever, but it will at least be better than the current one
Willing to go for a resonant antenna, you may consider putting up a resonant dipole, in such a case the calculation is pretty simple/straightforward
Lambda = 300000 / KHz
HalfWave = Lambda / 2
WireLength = HalfWave * 0.954
ArmLength = WireLength / 2
with the above infos in your hands, cut two wires at ArmLength and connect their center point to a 1:1 BalUn (yes, you want a BalUn there since it's a balanced antenna) like
this and connect the balun to the coax, hang the center as far as possible from the building (using a piece of rope) and hang the two arm ends (through ropes) to a couple supports outside, the dipole will then have an "inverted V" shape but will work w/o problems; to bring it to resonance you may just fold back (a bit at a time) the wire ends over themselves until you'll find the sweet spot
Ok, enough I think, hope it will be of some help
[edit]
The 0.954 factor I used is the velocity factor for "phosphor/bronze" wire, I prefer using that since, even if it will give you a (slightly) longer value, it's easier to shorten the wire than to lengthen it
[edit 2]
As for the "random wire" lengths, the table below shows them in meters, the first colum shows the "lowest" band which a given length will cover, the second one the length of the wire in meters, knowing the band of interest, pick the longest length which will cover the desired band (or a lower one) and fits your available space; notice that while laying out the antenna in a straight line would be the best setup, it's not mandatory, the antenna wire may be sloping or zig-zagging (horizontally and/or vertically) as long as the angles described are above 100 degrees, sure that will alter the radiation pattern, but it will allow to fit the wire into your available space
lowest band wire (meters)
20 8.8392
40 10.8204
40 12.4968
40 17.6784
80 21.6408
80 25.6032
80 32.6136
80 36.2712
160 45.1104
160 61.8744
160 105.7660
160 124.0540
160 128.9300
