Yes, measuring crystals and crystal filters would be a good one. I doubt it would work with that anti-gain, tuned amplifier I put together to demonstrate a case where the squarewave drives can cause a problem. If they cap the bottom end at 50kHz and it's closed source, the original may still out perform it on the lower end. Does the firmware crash after 10 minutes of use?
