I have a CMA382400AUP which is a 13GHz to 40GHz tripler and I see conflicting power supply voltages for it.
The seller indicates 5, 8, -5 volts but other paperwork says 12volts which I guess is for 8v line. Maybe.
The power out is low at 8v and varies when the 8 volt line is dropped. It looks like the 8v line is meant to be good to 12v which might give the 20dBm I expect. Obviously, I don't want to apply 12v and destroy it. Searches have failed me.
Does anybody know for sure what the voltages should be?
