Author Topic: Metal mesh to make 2.4ghz faraday cage for BLE/WIFI  (Read 10083 times)
Offline tautech
Re: Metal mesh to make 2.4ghz faraday cage for BLE/WIFI
« Reply #25 on: February 27, 2023, 11:30:23 am »
Soldering the edge joints of a woven metal mesh doesn't prevent bad contact between crossing  wires in the weave, hence my comments above.  I *really* wouldn't fancy trying to get a solder joint on every wire crossing in a fairly fine weave mesh - as, assuming a 3mm wire pitch, that's close to 4500 crossings to solder in a 20 cm square 'window'!  |O  :popcorn:
No problem with a 12mm iron tip and 3mm solder.
Properly prepped you could possibly drag solder it......if the iron element could keep up.  :-//
Offline jonpaul
« Reply #26 on: February 27, 2023, 12:57:23 pm »
a screen or mesh only needs joints bonded, welded,or soldered at the edges or frame
j
Jean-Paul  the Internet Dinosaur
