Author Topic: Possible antenna problem  (Read 1038 times)
Online veedub565Topic starter
« on: November 16, 2020, 04:58:15 pm »
Hi,  I'm a bit confused by a strange problem I'm having. Hoping it might seem a bit more obvious to someone more experienced.
My 2m rig measures 12W forward power and 1.00 vswr into a 50ohm load. When I connect my antenna I only measure 0.9W forward power and 1.06 vswr.
A few days ago I was measuring 12w forward power with the antenna connected. So I don't understand now what has happened. And I don't understand how the vswr can stay roughly the same,  but the power is so much lower.
Rig = Yaesu FT-480R
Antenna = Diamond X50
Coax = RG213 (8m length)
Ben
M7SCY
Oh and I used adhesive lined heatshrink on the antenna connector (N type) so as to weatherproof it.
« Last Edit: November 16, 2020, 05:02:03 pm by veedub565 »
Offline HB9EVI
Re: Possible antenna problem
« Reply #1 on: November 16, 2020, 05:17:33 pm »
how do you measure the swr?
Offline fourfathom
« Reply #2 on: November 16, 2020, 05:36:59 pm »
Yes.  Some SWR meters won't give reasonable readings with very low power, and if you have an antenna or cable problem your transmitter is probably backing off on the power to protect the output transistors.
We'll search out every place a sick, twisted, solitary misfit might run to! -- I'll start with Radio Shack.
« Reply #3 on: November 16, 2020, 05:55:50 pm »
I'm using a R&S NAS-Z5 insertion unit to measure forward/reflected power and VSWR
Offline HB9EVI
« Reply #4 on: November 16, 2020, 06:21:09 pm »
very likely you have either a cable or an antenna problem, so the transceiver lowers the output because of the mismatch, so you're measuring garbage.
in such cases you don't get far with an swr meter; if you don't have one of the widespread vnas, I'd recommend you to check the cable with the tdr method
check the antenna for eventual leaks
« Last Edit: November 16, 2020, 06:22:42 pm by HB9EVI »
« Reply #5 on: November 16, 2020, 06:47:28 pm »
Thanks, I'll get and investigate the antenna. Water getting in is the only thing I can think of.
« Reply #6 on: November 16, 2020, 07:59:48 pm »
I'm still getting a signal out by the way. My friend I talk to regularly still gives me an S8 report, although slightly down on the usual S9+
« Reply #7 on: November 16, 2020, 08:30:43 pm »
Fixed it, its the cheap N to PL259 adapter I'm using on the insertion meter.
Thats what you get for buying cheap adapters and connectors.
Offline HB9EVI
« Reply #8 on: November 17, 2020, 10:06:12 am »
yea, that's little surprising; the best setup/antenna is worth nothing if you have such a crap in the installation
glad that you found it!
