Hi
I am working on a project, where large currents are running on cables inside a cabinet. We are exceeding the radiated EMI limits.
So I am looking for a way to determine the impact on moving cables around, and the impact of the shielding effectiveness of the cabinet enclosure, for example distance between screws that fix the cover plates to the cabinet.
I have very little experience with OpenEMS, Ansys seems to have an easier flow, but cannot afford Ansys tools.
Is it possible, and if so, how hard is it to do a layout of placement of cables, define a current waveform in the cables, and then getting results that could correlate to a 3m measurement in an anechoic chamber?
Thanks
Klaus
