Author Topic: NanoVNA Custom Software  (Read 521164 times)
Offline joabel1971
Re: NanoVNA Custom Software
« Reply #2400 on: July 17, 2024, 12:59:43 am »
Joe:
The reason you might find this useful - is because this patent was only released to the public in 1995.   But, it was written 101 years prior to that.
Therefore, no existing EE books even discuss how to calculate this type of coil winding.
And, the patent claims it can hold 250,000x more energy - than a 1 wire coil.   Even modern Tesla Coils don't use this patent.
Having measurement tools to calculate this patent - might really change things - for everyone.   Can you help me?
Offline joabel1971
« Reply #2401 on: July 17, 2024, 01:45:41 am »
The information regarding 2-adjacent-wire characteristic impedance - on Stack Exchange says :
"Yes, wire diameter matters. Assuming the two wires are round and of equal diameter, the impedance is (120/√ϵr) * acosh(D/d), where ϵr is the relative permittivity (dielectric constant) of the material between the wires, D is the distance between wire centers, and d is the diameter of the wires.
In cases where the spacing is significantly greater than the diameter, you can use the simpler formula (120/√ϵr)*ln(2D/d).  This has less than 1% error when D/d is more than 3.6.
The velocity factor is simply (1/√ϵr), as user10489 points out.
Estimating ϵr can be tricky; for ladder line you need to figure something based on the material and the "fill factor" (how much of the space between the wires is occupied by plastic and how much of it is air). The goal of "open wire" feedline is to reduce this fill factor to nearly 0, which makes ϵr
decrease to nearly 1, and VF increase to nearly 1.
The dielectric constant of polyethylene is around 2.3; the ϵr of ladder lines made with PE webbing is between around 1.2 and 1.55, based on published velocity factors between 0.8 and 0.91."
Online joeqsmithTopic starter
« Reply #2402 on: July 17, 2024, 05:06:58 am »
I don't know how to measure characteristic impedance of patent#512,340.
Patented Jan 9, 1894.
Quick glance at the claims there is no metion of 250k...
Making adding more turns and cutting is certainly an option.   As far as what my software can measure, most of that has been covered in various videos, this thread and other documents I wrote.   That said, I would say my software is going to the same basic calcs found in any VNA.
Again,  it was patented 1894.  There's been plenty of time to change things...
If you needed something beyond the basic VNA math, don't loose hope.  There are several open source programs available.  Even if you have no programming skills to change the software, I would guess there are others that would be willing to add what ever features you need.  Consider joining the groups.io for the LiteVNA and ask.  I really don't know anything about these programs beyond they exist.
I've spent so much time and money, but I'm still having trouble finding people with enough experience to assist.
I'm not suggesting that you will find someone that will have any experience in what you are trying to do but they should need it.  I would hope you could just feed them the details on the exact algorithms you want implemented and hopefully, they can simply add them.
Offline joabel1971
« Reply #2403 on: July 17, 2024, 06:05:50 am »
5th paragraph from the bottom mentions "250,000 times as great":
Let it be assumed that the terminals of this coil show a potential difference of one hundred volts, and that there are one thousand convolutions; their considering any two contiguous points on adjacent convolutions let it be assumed that there will exist between them 'a p ptential difference of one-tenth of a volt. If now, as shown in Fig. 2, a conductor B be wound parallel with the conductor A and insulated from it, and the end of A be connected with the starting point of B, the aggregate length of the two conductors being such that the assumed number of convolutions or turns is the same, viz., one thousand, then the po- IOO tential diterencebetween any two adjacent lpoints in Aand B will be fifty volts, and as the capacity effect is proportionate to the square of this difference, the energy stored 5 in the coil asja whole-will now be two hunred and fifty thousand as' 'greatl'
I've contacted Essex (who I bought the magnet wire from).   Hopefully, they have the dielectric constant & velocity factor of their own wire.  Also, I used these interleaved coils to create AM electrolysis of water from 2011-2014.   I have experience with making these coils work successfully.   I just didn't realize all the work that still needed to be done.
http://arizonaenergy.org/News_12/News_Jun12/VolunteerJonAbelbannedfromNDSUforStanleyMeyerslabresearch.html
Again, the patent has only been available to the public since 1995.  This knowledge hasn't been written about - and is lost even to the colleges.
I wrote my own signaling software for the Propeller 2 board (a 54-channel signal generator - with duty-cycles, phase shifting, and wave-division multi-plexing), but I don't have any experience with these frequency-domain sweeping devices (NanoVNA, TinySA, TinyPFA) - or how to program them.   I would guess that not many hobbyists know how to program in the frequency domain.
Presenting the invention, to cause others to become interested is the hardest part.   But, if this is the path to creating BUOYANT materials (and maybe a new space-travel method), I'm forced to devote my life to it - no matter how little I know right now.
I do it - because nobody else appears to be going about it - in the correct way - not even "Applied Physics" (who just released Warp Factory software).
The handful of organizations attempting to build a warp drive - still seem to want to use "spacetime" and other non-Newtonian, relativistic concepts to try to get to the solution.  They forget that we cannot build non-Newtonian devices.
If you are a "trekkie" - then the first & only Newtonian solution for building a weightless, buoyant "warp bubble" is potentially sitting in front of you.
And, not to cause fear, but if the military & industry did keep patent 512,340 for themselves for 100 years - then we have been lied to about how nukes really work (and where gasoline comes from).  When coupling hidden knowledge - with financial & spiritual entitlements - means MOST people are not looking for the means to avoid our own depopulation.  Therefore, you may not see it yet, but I sense urgency to get this working - for everybody's survival.  It may sound odd but, my lack of any entitlements helped me design the solution.  I have no land, family, job, money, or religious entitlements - which can mentally hold people to this planet.  My project was built on 3 years of donations - that I collected through panhandling.   Only a handful of people appear to be attempting this type of R&D.
« Last Edit: July 17, 2024, 07:22:19 am by joabel1971 »
« Reply #2404 on: July 17, 2024, 12:45:05 pm »
Guessing you are not reading Tesla's patent 512340 that you referenced.  This would explain your date mixup as well.
 :-DD  They have no control over the application.
http://arizonaenergy.org/News_12/News_Jun12/VolunteerJonAbelbannedfromNDSUforStanleyMeyerslabresearch.html  [/color]
by Sterling D. Allan
Pure Energy Systems News
:-DD :-DD  Good timing as I recently mentioned them.
https://www.eevblog.com/forum/dodgy-technology/ashton-forbes-over-unity-challenge/msg5538713/#msg5538713
The internet has made it easier to search them but they have always been available.
Again, you have the source code, so shouldn't pose much of a problem.
I personally wouldn't have any interest but the internet is vast. A quick search, looks like you have found a few others:
https://douktris.wordpress.com/2015/03/18/the-tragedy-of-eric-dollard-and-the-fall-of-aaron-murakami-2/
If you are a "trekkie" ....
I'm not.  Rare I watch TV.
And, not to cause fear, but if the military & industry did keep patent 512,340 for themselves for 100 years - then we have been lied to about how nukes really work (and where gasoline comes from).  When coupling hidden knowledge - with financial & spiritual entitlements - means MOST people are not looking for the means to avoid our own depopulation.  Therefore, you may not see it yet, but I sense urgency to get this working - for everybody's survival.  It may sound odd but, my lack of any entitlements helped me design the solution.  I have no land, family, job, money, or religious entitlements - which can mentally hold people to this planet.  My project was built on 3 years of donations - that I collected through panhandling.   Only a handful of people appear to be attempting this type of R&D.[/color]
My advice would be to avoid presenting yourself as delusional.  Stick to the details of what you want to learn.  This site does seem to tolerate chat on perpetual motion, religion, politics, sexual preferences ...  to some degree.
I suggest starting a new topic under Dodgy Technology.
Offline joabel1971
« Reply #2405 on: July 17, 2024, 04:02:05 pm »
Not a mixup - right off this link - https://patents.google.com/patent/US512340A/en
Not sure what you are reading.  Respectfully, are you blind?
I'm not saying they do.   I'm just trying to understand what is missing from frequency domain sweep software - and what would be necessary to make it give more robust results.
Ah, I see - obviously you've made your conclusions already - even though you've never attempted to make AM electrolysis work.
Scientists run the risk of stalling by becoming "Doubting Thomas'" - instead of attempting the leg-work.  You might try looking a little harder next time -
AM electrolysis is quite real.
Regardless, there are no formulas to calculate patent 512,340 (interleaved coils).  I will gladly look at any proof you have otherwise.
That sounds like a blowoff.   I don't think most people have time to go through other people's undocumented code.  I would start with simpler software anyway - instead of wading through thousands of lines of your code.   Your suggesting a newbie rewrite your code?  Hardly.
I was just looking for specific functioning - but I'm too late since you've already made your decisions about patent 512,340.  Disappointing.
Once again - I see I'm barking up the wrong tree.   I'm sorry you are unwilling/uninterested at looking at such easy, successful radio experiments.
Here's another successful attempt I did :
Setup took 20 minutes.
That's a shame, it can help you create new experiments.   Applied Physics is offering grant funding for new warp drive designs.
Maybe you think warp drive is impossible too - because of what you've read or been told?    I guess you are just a programmer.  That's disappointing.
And, not to cause fear, but if the military & industry did keep patent 512,340 for themselves for 100 years - then we have been lied to about how nukes really work (and where gasoline comes from).  When coupling hidden knowledge - with financial & spiritual entitlements - means MOST people are a not looking for the means to avoid our own depopulation.  Therefore, you may not see it yet, but I sense urgency to get this working - for everybody's survival.  It may sound odd but, my lack of any entitlements helped me design the solution.  I have no land, family, job, money, or religious entitlements - which can mentally hold people to this planet.  My project was built on 3 years of donations - that I collected through panhandling.   Only a handful of people appear to be attempting this type of R&D.[/color]
I am indeed sticking to those details & offered my motivations.  I'm sorry you don't like my motivations, but it doesn't change the fact that I will need Custom VNA software to measure, analyze & model interleaved coils.   Again, if you have found formulas for interleaved coils - you are welcome to share.
Once I learned to question the opinions of Wikipedia - I was able to construct AM electrolsysis experiments & see for myself - that AM electrolysis worked and was not fraudulent.  This was 13 years ago.  After that, it was just a matter of testing my own cell-phone for radiation, reading food ingredient labels, personally experiencing the damage caused by the fracking industry, personally experiencing the motives of the higher education industry,  and asking hard questions about our government's ability to help or hinder the public  - to see how easily the public can be steered by it's leaders (for good or for bad).
However, instead of saying "speculation" - you headed straight for the "delusional" insult.  Again, very knee-jerk.   Your cognitive dissonance and/or  bias is not a new experience.   It appears you have something to lose by even considering how interleaved coils work.   If you are a college professor, then your job might rely on such opinions - but if you aren't working for a college - then you are free to consider any scenarios you want (even if just for 30 seconds).  Knee-jerk conclusions & insults make you appear entitled & scientifically benign with regards to this type of brainstorming.
Regardless of your interest (or lack of) - I suggest you stop trying to defame other people's scientific pursuits.  I need help with custom VNA software.
I also suggest you learn to wrap some interleaved coils - and try it yourself.  I'm busy looking for people who haven't killed their own imagination with entitlement - which obviously limits their ability to question, and consequently use the scientific method effectively.
My experiment showing how much radiation a cellphone is capable of - by overloading a Geiger Counter (only possible by asking hard questions about safety standards) -
« Last Edit: July 17, 2024, 04:04:14 pm by joabel1971 »
« Reply #2406 on: July 17, 2024, 04:40:22 pm »
 :-DD
I am not here to provide you with proof of anything.
My software has never been open sourced or published.  Nor have I ever suggested anyone including yourself attempt to rewrite it.
Applied Physics is offering grant funding for new warp drive designs.  Maybe you think warp drive is impossible too - because of what you've read or been told?    I guess you are just a programmer.  That's disappointing.
:-DD :-DD  I think you just insulted all the professional programmers.   :-DD :-DD :-DD
A few minutes of searching, I did turn up a few gems.   Pattern has been there for a while.
https://ask2.extension.org/kb/faq.php?id=661665
https://ffrf.org/images/uploads/fttoday/2020/FT28_Jan-Feb_2020_web.pdf
I don't think you have actually figured that out yet.
Offline joabel1971
« Reply #2407 on: July 17, 2024, 05:29:45 pm »
 :-DD
What pattern & gems do you speak of?   Discrediting someone for asking for scientific help says more about you - than me.
I'm sorry if my experiences offend your sense of truth - but they do happen.   And you posted them.  Thank you.
But if you are going to quote questionable blogs - regarding attempts at social networking I made from 5 years ago - then your intentions are clearly to not to assist.
Again, your actions are not a new experience to me - just another example of a cognitive defense mechanism.
Haven't figured out what?  That you would rather attempt to discredit someone's request for assistance - instead of updating your software?
No, I'd say I'm spot on.
« Reply #2408 on: July 17, 2024, 05:38:20 pm »
From your link above:   "City of Moorhead explicitly won't issue a permit inside city limits. "
Assuming 1971 was when you were born, going back 10 years you would have been 43 or so.
https://www.inforum.com/newsmd/moorhead-man-accused-of-stalking-his-former-microsoft-call-center-manager
Looks like a lot of layoffs at Microsoft in Fargo
https://www.reddit.com/r/fargo/comments/2gs1l3/microsoft_layoffs/
Offline joabel1971
« Reply #2409 on: July 17, 2024, 05:47:21 pm »
You've been reported to the Forum Moderators - for defaming & derailing my request for updates to your software.
Whether are a discussion-bot or just an insecure web-surfer - either would explain your need to stray from topic.
« Reply #2410 on: July 17, 2024, 05:50:12 pm »
While I could not find any records of an actual arrest,  a couple years later:
https://www.havredailynews.com/story/2018/10/01/local/for-the-record-oct-1-2018/520654.html
Offline joabel1971
« Reply #2411 on: July 17, 2024, 05:56:44 pm »
There are multitudes of people - including professors, and a Christian musician that share my name.   Are you going to say that I am them, as well?
Obviously, you are just a another discussion-bot.
Offline joabel1971
« Reply #2413 on: July 17, 2024, 07:04:36 pm »
https://www.riversideiowa.gov/files/meetings/2020-10-05_packet_city_council_69094.pdf
Gee, if you spent as much time updating your software - as you do attempting to defame an honest request - then I wouldn't have had to request a software update to handle interleaved coils.    Any other "stories" you want to try to link me to - discussion-bot?
« Reply #2414 on: July 17, 2024, 07:28:49 pm »
... if you spent as much time updating your software - as you do attempting to defame an honest request - then I wouldn't have had to request a software update to handle interleaved coils.
You may feel I owe you my time or should have a say in how I spend it, but that's just part of being delusional.   Once in a while someone actually comes up with an good idea and I will implement it.   In your case, you're just not presenting anything I find as having any value.
As I stated, you have not figured that out yet but we can continue if you like.
I did manage to find your current ham license so at least you have that to fall back on.
Offline joabel1971
« Reply #2415 on: July 17, 2024, 08:08:42 pm »
On discussion groups - you only owe people civil, related responses, or you get reported for acting hostile.
So, that's what you get.    So, continue all you wish.
« Reply #2416 on: July 17, 2024, 08:32:21 pm »
You actually wasted the admin's time for my calling out your delusional comments of space travel and how your have been mistreated all your life being handcuffed and escorted off the property for your obvious superior intellect?    :-DD :-DD :-DD   No one here owes you anything.
Offline joabel1971
« Reply #2417 on: July 17, 2024, 08:36:40 pm »
That's a typical response from an AI chat bot.   Right, Eliza?
Offline joabel1971
« Reply #2418 on: July 17, 2024, 09:30:16 pm »
Go ahead, continue if you wish.
Offline joabel1971
« Reply #2419 on: July 17, 2024, 09:32:43 pm »
Offline shakalnokturn
Offline joabel1971
« Reply #2421 on: July 17, 2024, 11:48:16 pm »
Offline EEVblog
« Reply #2422 on: July 18, 2024, 03:37:43 am »
As per our private conversation, you are one step away from being banned.
You have no right to demand that Joe spend his time updating his software to suit you.
The following users thanked this post: mikerj, joeqsmith
Offline Gyro
« Reply #2423 on: July 18, 2024, 06:53:59 pm »
An AI chat bot who has been an active and valued member of the forum since 2015. His development was clearly ahead of it's time.  :-DD
Best Regards, Chris
Offline joabel1971
« Reply #2424 on: July 18, 2024, 07:01:26 pm »
[/quote]
That's nice.   However, I have no reason to trust his software at this point.   I'll stick to the classic NanoVNA-App.
For my purposes - it's more effective software than Joe's over-bloated, untested "mystery-ware".
I mean, who is this guy really - other than what I've experienced as a defamator & a liar?
