Author Topic: NanoVNA Custom Software  (Read 539492 times)
croma641, ON7CH and 7 Guests are viewing this topic.
Offline joeqsmithTopic starter
Re: NanoVNA Custom Software
« Reply #1800 on: March 02, 2022, 01:11:42 pm »
Using my V2+4, I lowered the supply voltage like we had with the LiteVNA to solve the noise problem.  Even with as low as 4.5,  there was no improvement.
Offline jspencerg
« Reply #1801 on: March 02, 2022, 04:33:04 pm »
Re: VI window size
First impression indicates newer versions of Labview have ability to adjust window size for monitors of different resolution. I don't know whether those functions are available for Labview 5. I'll look into it.
« Reply #1802 on: March 02, 2022, 04:51:40 pm »
Re: VI window size
I haven't used LV5 in I would guess 20 years.  For your demo, just use what ever version you have available.
Offline jspencerg
« Reply #1803 on: March 02, 2022, 05:15:44 pm »
What version of Labview are you using to create the program?
« Reply #1804 on: March 02, 2022, 05:24:50 pm »
Re: Getting started with hardware.  Versions and connection success.
1. Versions
"THIS IS NOT THE LATEST RELEASE AND ONLY SUPPORTS THE V2 PLUS. IT SHOULD BE INSTALLED FIRST!"
I've installed and am running the program. Indicates it is Rev 0.10.
Where is Rev 2.05 & 2.07 as shown in manual?
2. Connection state looking good.
Windows Device manager sees the nanos' connections.  As stated in manual, this install(0.10) links with the v2plus4 but not the original nano. I look forward to comparing results from the two.
Make sure you select the correct branch.
https://www.eevblog.com/forum/rf-microwave/nanovna-custom-software/msg4021102/#msg4021102
Of course....
https://www.eevblog.com/forum/rf-microwave/nanovna-custom-software/msg4021555/#msg4021555
« Last Edit: March 02, 2022, 05:26:57 pm by joeqsmith »
Offline jspencerg
« Reply #1805 on: March 03, 2022, 02:24:01 am »
I knew that LV11 had been used. Your discussion of 64-bit version and the program's new name suggested you were updating program as you develop next version. Correct?
« Reply #1806 on: March 03, 2022, 02:44:31 am »
Correct
« Reply #1807 on: March 03, 2022, 02:46:51 am »
Flipper's transfer relay is NOS.  He cheated with an OTS DC-DC rather than rolling it from scratch.   It's a much nicer setup than mine.
Offline nctnico
« Reply #1808 on: March 03, 2022, 01:47:21 pm »
1. Versions
Of course....
But that message is still clear as mud -sorry-. Why not write down some simple steps that people can follow instead of needing to find bits of information in documents, this forum and videos? The problem is that a lot of the installation part is obivous to you but it isn't obvious at all to other people. Someone new to your software needs a single place with a full instruction on how to get your software going without needing to go on a scavenging hunt for information (like it is now).
As far as I understand it right now the installation boils down to the steps below:
  • Go to the github page: https://github.com/joeqsmith/NanoVNA_Software
  • Look at the right under releases, download all the zip files, extract to a directory and run the installer (setup.exe ?). This will install the NI Visa (version x 32bit) and Labview runtime (version y 32bit)
  • Go back to the github main page
  • Click on branches in the left top
  • Open the branch for your NanoVNA model and download the .exe file onto your computer
  • Start using the program
Please amend these steps with missing info and add them to your Github page and manual. I'm 100% sure you'll see a huge drop in questions about installation issues.
Assuming these steps are correct, I would have had your software up & running within 5 minutes.
« Last Edit: March 03, 2022, 02:31:36 pm by nctnico »
« Reply #1809 on: March 03, 2022, 02:40:39 pm »
Of course....
But that message is still clear as mud. Why not write down some simple steps that people can follow instead of needing to find bits of information in documents, this forum and videos? The problem is that a lot of the installation part is obivous to you but it isn't obvious at all to other people. Someone new to your software needs a single place with a full instruction on how to get your software going without needing to go on a scavenging hunt for information (like it is now).
Define simple.  After providing you a screen shot from Git that answered your question about 32 or 64, you still asked the same question.  So even just a few sentences, one which directly answered your question is not simple enough.
Rather than having such expectations of me, what prevents you personally from writing what ever documentation you feel would help other users?   You could start a Wiki page for it, make instructional videos and what ever else you feel is a benefit to the community.
I have no plans to do anything more with the original repository.
« Reply #1810 on: March 03, 2022, 03:42:32 pm »
By far most questions were sent in by PM or direct email asking how to use the software.   Most have been from CB/amateur radio hobbyist regarding antenna measurements.   This group expresses a level of expectation when it comes to supporting them.  I delayed the original release by about a year because of the constant complaints and demands.   Anymore, I rarely take the time to answer private emails and in some cases block them.
Point being, you are asking about what I consider a trivial problem that again, you personally could help make a difference if you chose to.   The bigger problem is educating people on it use.
« Last Edit: March 03, 2022, 03:44:09 pm by joeqsmith »
Offline nctnico
« Reply #1811 on: March 03, 2022, 03:56:57 pm »
I understand but I still believe that information regarding installation should be contained in as few places as possible. That has made me hesitate for a long time to post my idea on how the installation steps can be made more clear. On the forum it just gets lost in the noise and I don't see how another wiki page adds something of value. Especially given the fact that there are several software packages out there to use one of the many NanoVNA models out there.
As to using your software; the NanoVNA has opened up owning a VNA to a lot of people to whom such a device was out of their budget and/or not worth having. So I'm not surprised you get a lot of questions from people to which the technical terms are not familiar.
« Reply #1812 on: March 03, 2022, 04:38:29 pm »
I believe if we look at your specific question where the information was provided in a few sentences was too much to read.  I doubt adding a list of instructions would have enticed you to read them.   Lack of reading skills is a common problem in general and why I will not invest any time towards documenting new releases.
Git offers very little for metrics to help track the number of users.  I suspect my small channel and free software has done little to help the community.   I try to steer people away from using my software and to use one of the other open source programs.   These have a large user base and I assume much better support.
It should be clear by now that my business model is such that  I don't make any money from my attempts to help the next generation of EEs.  You don't see me begging for money to fund my efforts.
Offline jspencerg
« Reply #1813 on: March 05, 2022, 05:35:59 am »
Re: front panel sizing
I realize you've got bigger fish to fry.  I'm just trying to make a little contribution. I've only been able to find one way to maintain percentage of front panel coverage with different monitor resolutions.  This solution speaks directly to current issue. However,  scaling issues with inserted graphics and fonts might be problematic. In any case,  trying it couldn't hurt:
https://zone.ni.com/reference/en-XX/help/371361R-01/lvdialog/window_size_properties/
Thanks for your work.
« Reply #1814 on: March 05, 2022, 05:56:26 pm »
True and true.  Until you take that first step to learn about what you are suggesting,  you're not contributing anything but noise.  Maybe ask yourself,  Joe's says he's been using Labview for decades.  Why doesn't he listen to me...    :-DD
Scaling is an interesting problem and I would certainly take the time to show you a few tricks if you decide you want to learn it. As you're discovering,  the basics can be found with Google.  Use these to build your own understanding of how it works.   Maybe start a thread in the programming or test equipment sections to discuss learning LabView.  You may find others having something to contribute.
Again:
Who knows what you were expecting.  Maybe you expect the graphs to scale.  Obviously the font sizes are fixed.   There are videos on YT about designing software with LabView using the autoscaling if you are interested in learning about it.
I've run my VNA software on 1280X1024 19", 1920X1080 27" and 1920X1200 24" and its very easy for me to read on them all.   It is designed to run on my laptop which has a 17" display.
You should consider running  one of the popular open source programs.  If you really have some need to run my software and your choice of monitors was poor for your eyesight,  just buy a new monitor.  They are cheap.
« Reply #1815 on: March 06, 2022, 04:48:40 am »
Flipper's second LiteVNA arrived today.  Using the same USB cable, PC, port, his has very poor performance.  The serial number on mine is about 150 higher than the problem unit.  I'll ask about the SN# for second Lite he bought as it also shows much worse performance.      Looking at the two, I don't see anything major sticking out but maybe they made an improvement with the newer units.
I would think their final test would have caught it but maybe the older ones are just poor and they had changed the design.
« Reply #1816 on: March 06, 2022, 05:25:25 pm »
In Lite if remove DC block capacitor and ESD protection diode possible get better results on low frequency range < 10M (but this huge increase chance burn rf switch)
I prefer not do hardware mods (use for firmware tests only original hardware)
No problem.  Did you see this data published somewhere that you can provide a link to it?
https://groups.io/g/liteVNA/message/210
When pulling the blocking capacitor, what is the common mode range?  Would P1's source have a DC bias?
Would it be better to keep the block but change the value?   I don't see a problem pulling the protection diode but find it odd it would improve the low frequency range.
Lack of schematics makes some of this a total guess.  Plan is to modify Flipper's one bad unit and see if indeed there are any performance gains.
Offline realfran
« Reply #1817 on: March 07, 2022, 12:39:43 pm »
Hello, the flipper is one new device?
« Reply #1818 on: March 07, 2022, 04:02:08 pm »
 :-DD  If you type in Flipper, then select the Search:
My friend Flipper ...
Flipper and I have been testing ....
I bounced it off my friend Flipper ....
Offline realfran
« Reply #1819 on: March 07, 2022, 05:00:33 pm »
Hoo! Luck good :-DD For people with software typewriter skills can dump the close NanoVNA V.2Plus4 firmware and open it for different FW?
For me is a problem I'm ignorant of typewriter software.
« Reply #1820 on: March 07, 2022, 06:28:59 pm »
Maybe ask OWO in the mail group.   Dislord has already posted about the V2+4 being locked.   I suspect OWO's recent updates were firmware changes.   I doubt they will be making that available for free.   You may not see any further development on the V2+4.
I suspect most new buyers would purchase the Lite rather than the V2+4 because of the higher operating frequency, able to make narrow band measurements, much lower cost and the firmware is being maintained and continues to be stable.
Offline realfran
« Reply #1821 on: March 07, 2022, 09:42:13 pm »
the v.2plus4 is the firmware on the screen module is closed, the other can install Dislord fw, if the pc software makes the measurement is a very expensive upgrade from OWO with the same amount of money I buy other two LiteVNA  :-DD
Offline irpheus
« Reply #1822 on: March 08, 2022, 09:20:01 am »
Hi all,
I am posting here because I am very interested in using Joe's software for PDN measurements.
To this end I have bought what I assumed/thought is/was informed should be an original NanoVNA, however, it appears to be a NanoVNA-H (bought from eleshop.eu which only sells "original" nanoVNA (H)s, according to their website  https://eleshop.eu/nanovna-h.html ).
Reading through this thread it seems as if Knuddel in #1155 with some challenges made the NanoVNA-H work with the software ... however, there's no final confirmation of this in the pages following this post #1155 (as far as I can see) ... ?
In any case I am very genuinely interested in using this fine software for PDN measurements and somehow need to find a way either to:
- make the NanoVNA-H that I have bought work with Joe's software (much preferred), or
- find a vendor that sells the genuine "original nanoVNA" ...
Help into either of these possibilities would be very much appreciated  ;)
Jesper
" ... It is always possible to be friendly ... " H.H. the Dalai Lama
Offline realfran
« Reply #1823 on: March 08, 2022, 01:40:34 pm »
Hello Jesper, the first thing is to read the manual after downloading the software, watch Joe's Videos on the subject when connecting your NanoVNA start to test it, make the NanoVNA-H that you have bought work with Joe's software.
« Last Edit: March 08, 2022, 01:44:40 pm by realfran »
« Reply #1824 on: March 08, 2022, 02:39:13 pm »
Hi all,
Jesper
Jesper,
You and jspencerg have a lot in common.  Had you read Knuddel and my posts following #1155, you know that their problem was due to their regional settings which has been covered many times.  I suggest you make use of the search feature.   It's very easy to use (see attached).  I suggest searching "regional" or maybe "comma".
Of course, you never state what problem YOU are having.  Only that you need to somehow make it work.  Assuming you are running the latest software, the regional settings should be handled automatically so maybe you are having some other problem.  Maybe you have the wrong software, wrong VISA, no VISA.  Rather than my guessing, how about you provide a few details.
